Question about Dryers
Westinghouse ld605e The cylinder on my westinghouse_ld605e dryer has stopped rotating when dryer is switched on. The Motor on machine hums but does not begin to turn the cylinder. I have checked the belt, bearing etc everything seems fine with back off. Thanks in advance
    Top Expert:
  • Dryers Master
  • 44,894 Answers
The belt may look OK but could be slipping due to stretching.
Posted on Dec 30, 2013
AlmostBob
  • 550 Answers
SOURCE: i just bought a second
The LD605 series of driers is wall mountable and stackable
When wall mounting, the drier is hung 'upside down' with the knobs at the bottom to allow access, by people less than 8 feet tall.
The original package came with wall mounting bracke, and replacement sticker for the control panel with the text upside down so that it would be right way up when the dryer was hung.
If you arent going to hang the dryer, examine one small corner of the label area, the original label may be underneath and exposed by removing the wall hanging label.
The current model in the LD605 series still comes with wall mounting kit
http://www.westinghouse.com.au/product/display/model/LD605EB
Posted on Oct 11, 2008
Illeagle
  • 525 Answers
SOURCE: Drum not rotating
If you clean your lint filter after each load faithfully, try removing the dryer vent hose that goes to the outside and inspect it for lint accumulation, water build up, or some other foreign material, as this will restrict air flow and cause your described symptoms. If your are unable to inspect your vent, disconnect it from the back of the dryer and start your dryer to see if it works that way.
Posted on May 29, 2008
  • 249 Answers
SOURCE: Dryer won't run
power pack, or condensur is faulty that stats the motor fit new one .close says!
Posted on Nov 30, 2008
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
  • 52 Answers
SOURCE: Dryer drum turns for a second...stops and then motor hums?
I have a strong feeling the motor is seized or at least in the process of... I would recommend a new motor. If you are mechanically inclined, it's a very easy process. If you need help, I would be more than help to walk you through it.
Posted on Feb 24, 2009
Westinghouse de600a0dw2
You'll have to trouble shoot it... the belt either jumped off the motor pully or it may have broke. Either way you'll have to disconnect it and inspect it. Remember to always unplug the unit when servicing it. If the belt broke it is not hard to replace. The drums are held by gravity on rollers. Simply lift enough to get new belt pass the roller. If there are upper rollers in the way... simply remove them. Don't remove lower rollers. Lift the drum enough to install the belt and replace the upper rollers, relocate the new belt and close it up. Done.
Dec 25, 2013 | White-Westinghouse White Westinghouse...
Westinghouse LD605E dryer drum belt replacement.
Go to www.repairclinic.com and enter LD605E. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Westinghhouse video showing disassembly and belt replacenent.
Aug 31, 2017 | Dryers
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
LOUD HUM NOISE
check bearings or shock absorber.
Feb 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
I just bought a second hand westinghouse dryer 6kg LD605E, the sticker on the machine is upside down and the seller told me that the machine can be used either way. it this true? thanks
Oct 11, 2008 | Dryers
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Open Questions:
Dryers Logo
145 people viewed this question
Top Dryers Experts
