Question about Photography
Nikon error code
I have a nikon D 5100. Suddenly when in turn it on and try to take a picture, the error " err 40F5" appears on the display and the picture is not taken. What is this error?
    Top Expert:
  • 6,702 Answers
This error the manual says: please contact the Nikon service centre closest to you. You could try to switch of the camera, remove the battery and replace it and then switch the camera on again, but if the error comes back you should contact Nikon.
Don't forget to check if everything on you camera is ok.
Battery charged, lens correct mounted. Memory card with enough space to save pictures )(correct format)
Posted on Jan 09, 2014
4 Suggested Answers
cammedic
  • 667 Answers
SOURCE: fee to error
Remove the batteries for 5 or 10 minutes. Remove the lens from the body and replace it. Make sure the lens is on f22 before you put the batteries back in and turn on the camera. If this doesn't solve it, try rewinding the film you have in the camera and try a new roll. The other thing to check if none of the above works is to remove the lens and check the small tab just on the outside of the mount ring at about 7:00. The tab is spring loaded and you should be able to push it with your finger and it will snap back. If it doesn't, the tab plate will need repaired or replaced
Posted on Dec 26, 2007
Gryfox
  • 216 Answers
SOURCE: Nikon N75 - error message, nothing working.
You have to reset the rewind counter by pushing the two buttons simultaneously - one on the side of the lens mount, the other by the release button - red, cassette symbols. This tells the camera there's no film in it.
Posted on Dec 06, 2008
pontelemon
  • 531 Answers
SOURCE: err message when shutter is fired
Shutter motor is jammed and needs to be replaced.
Posted on Apr 02, 2009
On my nikon D 5100 an error code appears when i try to take a picture. It states " err40F5" what is this error! ? Tha ks,
Change the SD Card, because it might be corrupted or writing speed was not enough.
For Nikon D5100, it is recommended to use SD HC Class 10 card.
Dec 30, 2013 | Photography
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
"Err" error message when i try to take a picture
probem of the shutter loader unit replace wih a new one
Mar 01, 2010 | Nikon D70s Digital Camera
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
Error code : err
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
NOTE: Please rate our help to keep this free service online
Jun 19, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
Nikon D70 Err
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
Nov 09, 2007 | Nikon D70s Digital Camera with 18-200mm...
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
