Question about Sport & Outdoor - Others
Paintball manuals gun has to be cocked for every shot
  • 11 Answers
SOURCE: i need to find an online manual or someone who has
http://www.bansheepaintball.com/library/Shocker_NXT.pdf
Posted on Sep 10, 2010
  • 15 Answers
SOURCE: I attempted to put a car stock on my Tippmann 98
Check the O rings on the big metal striker, make sure that you have the spring on the back (where the stock would have went) in the right hole on the back plate. Make sure that your velocity is set to a reasonable level.
Posted on Jan 03, 2011
  • 111 Answers
SOURCE: fix view loader brawler
The first time you might check with your local paintball store or airsmith and let them walk you through it. That way you can ask questions and see it in action.
You can check out the website and get a parts breakout which will show you how it all goes together in one picture, and the user guide gives you the basic information for standard maintenance. But again, being able to ask question while seeing it done may go a lot farther towards enlightenment.
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
  • 111 Answers
SOURCE: paintball gun problem
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
8^)
ozark333
  • 396 Answers
SOURCE: Tippman A-5 with low pressure
Sounds like the gun needs lube. Oil it and try again. 2-3 drops of oil in the hole
where the tank screws on then put the tank back on. Fire it and see how it does.
I havent heard of a low pressure kit for the A-5 but I think it is a waste. There is a rule
with pressure and paintball guns. Low pressure=high volume of air used.
Standard pressure=regular volume. I have 2 a-5's with e-grips and flatlines.
I polished the internals by sanding the bore of the tube (use fine sandpapaer) and
this makes the velocity very consistent.
One thing that comes to mind is that the hammer may not be getting caught on the
trigger latch. Makes sure your gun is assembled correctly. here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Posted on Mar 14, 2011
My Tac-5 Recon marker does not shoot the paintballs. I cock the marker and after I pull the trigger I can feel and hear the spring action but no paintballs are launched. When I attached the CO2 tank I did...
take the hammer and bolt out, clean them and oil them with paintball oil (no motor oil or WD-40)
air tool oil also works, but besides paintball and air tool oil, never use anything else.
the bolt is in the front of the marker, it is what pushes the paintball from the breach into the barrel. the hammer will be towards the back. its been years since i have touched a tac-5
easiest way to oil is just to put a few drops in the asa (where you attach the tank) and dry fire with the barrel off a dozen times. this will get the oil everywhere it needs to be.
if you can take it apart and clean it i would still recommend that
Jan 05, 2018 | Tippmann A 5 Standard Paintball Gun
The Rear Bolt wont **** fully
it sounds like your bolt is upside down try rotateing it 180 degrees
Dec 31, 2012 | Tippmann 98 Custom Act Paintball Gun
When I connect the cylinder to the gun all the gas escapes, can you help
The easiest and most likely solution is that you don't have the marker cocked. If you haven't done this, try cocking the marker and then screwing on your gas.
Feb 19, 2011 | Tippmann A 5 Standard Paintball Gun
Tippman A-5 with low pressure kit, e-grip. When pull the trigger gun shoots fully auto until I manually stop it by re cocking the gun.
Feb 15, 2011 | Tippmann A 5 Standard Paintball Gun
I attempted to put a car stock on my Tippmann 98 custom and took apart the gun but the stock didnt fit, now when i put it back together and shot it with my tank connected the gun wont stay cocked and...
Oct 02, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Wont stay cocked
If you ran out of air, it won't stay cocked.
OR
The sear may have been displaced. That would require a disassemble. It is not that difficult, just do it on a white pillowcase and be sure not to let any springs fly all over the place.
Aug 05, 2009 | Tippmann 98 Custom Act Paintball Gun
Sport & Outdoor - Others Logo
98 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
