Question about XM Radio XM Direct 2 Mini-Tuner Car Kit for XM Ready Aftermarket Radios Satellite
I need to program my cnp2000uca
I need to program the Protocol Interface Adapt
How to switch on poe function at switch port
Hi
Instructions
telnet to the IP address of the Cisco switch
Enter the telnet access password for the Cisco swict when requested, and then the "Enter" key.
Type "enable" at the command prompt, and then the "Enter" key.
Enter the Privileged Exec password when requested at the command prompt, and then the "Enter" key. Then enter "configuration terminal" at the command prompt, and then the "Enter" key.
Type "interface fastethernet0/1," replacing the "fastethernet0/1" with the name of an interface in which you wish to enable PoE, and then the "Enter" key. Then, while in interface configuration mode, type "power inline auto" and then the "Enter" key. Repeat this step for each interface in which PoE is required.
Type "end" at the command prompt and then the "Enter" key, copy running-config
Below is some commands to run, I don't have any power on the interface but this will show you if this is working...
SW1#sh power inline fastEthernet 0/1
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Run this command to see the interface is up.....
SW1# sh interface fastEthernet 0/1 ' in protocol
FastEthernet0/1 is up, line protocol is up (connected)
SW1#sh cdp interface fastEthernet 0/1
Encapsulation ARPA
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
Thanks
Jul 31, 2014 | Cisco Catalyst Computers & Internet
Teredo Tunneling Pseudo Interface cannot connect or start
If this message is in windows, then it is all driver problems. Try going to the intel website and looking up your motherboard, there should be several drivers in multiple categories to download, or one package, get the newest ones and install them all. Intel Driver Update Utility
Apr 14, 2014 | Intel Desktop Board D845GLVA...
I need help with cisco asa 5505 ssl vpn.. ssl
The total sum of the Inside/Outside/ and pool address add up to 5,265. Subtract 10% and multiply by 260 to get the gender aspect of the original formula. Move the Network address to Google and download the residual code offered by the program that appears in the open window. Enter the code in the appropriate space provided and this will solve the problem by late 2015.
Oct 09, 2013 | Cisco ASA 5505 Firewall
Unable to load client protocol
b> Internet Protocol, also known as IP, is a communication protocol which heavily uses the TCP/IP standards for packet switch internetworking. IP manages addressing methods for data encapsulation and delivery. IP was developed by the United States Department of Defense and is now widely used by the public. IP Version 4 is the fourth version of Internet Protocol and the first one to be deployed to the public. Updating and installing Internet Protocols are important to the integrity and reliability of your Internet connections.
Click the "Start" button at the bottom of your desktop screen. Click on "All Programs." Select "Run" from the Accessories folder. Type "CMD" in the run dialog box. The command prompt window will appear. Type "Netsh Interface ipv4 install" on the command prompt line. Press "Enter." Restart your computer.
Add or remove a network protocol, service, or client
http://windows.microsoft.com/en-GB/windows7/Add-or-remove-a-network-protocol-service-or-client
Feb 06, 2013 | Microsoft Internet Explorer 8
Trouble code 9141
ElmScan ISO is a PC-based scan tool, and our most popular OBD-II interface. It supports the ISO9141-2 and ISO14230-4 protocols used mostly in Chrysler Corporation, European, and Asian vehicles. Be sure to determine the communication protocol used in your vehicle before purchasing this scan tool.
Processor: ELM323, crystal-controlled for accuracy
OBD-II Protocol: ISO 9141-2 and ISO 14230-4 (KWP2000)
Output protocol: RS232
Indicator LED's: OBD Tx/Rx, RS232 Tx/Rx, Power
Operating voltage: 12V, internal protection from short circuits/overvoltages
Dimensions: 3"x4" (76x102 mm)
The interface can be used in conjunction with our free software to turn your laptop or desktop computer into a fairly sophisticated auto diagnostic system. The ScanTool.net program has a built-in database of more than 3000 trouble codes, and allows you to read and erase stored trouble codes and oxygen test results, turn off the MIL ("Check Engine" light), and display real-time sensor data. For more information about the program, please visit our Software page.
Jul 22, 2012 | 2001 Toyota RAV4
Port getting flaps
sounds like some sort of keep-alive problem.
Try using
switch(config)# debug snmp packets
this will show you what is causing the line protocol to drop. you need to be connected to the console to see the output for this and turn it off when your done.
un debug all
good luck.
Jun 06, 2012 | Cisco Catalyst 4948
Breaking password on cisco 857w
When the router first starts booting you need keep hitting the break sequence which should be crtl+F6 and that should bring you to ROMMON mode. you should get a prompt rommon 1>, that means you did it right. Now you need to change the configuration registers to 0x2142 by typing "confreg 0x2142". then type reset to restart the router. It should now ignore the saved config. hit crtl+c to cancel the initial setup, type "enable" to get to the enable prompt. Next type "copy startup-config running-config" to copy the startup configuration to the running configuration. Next type "configure terminal" to enter global configuration mode. Now you can type "enable secret <password>" to change the password to what you want. Last you need to change the config registers back to 0x2102 by entering the command config-register 0x2102.
Feb 17, 2012 | Cisco 857 ADSL Wireless Router...
My computer cant find a driver to program the adapter
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Mar 20, 2011 | Audiovox CNP2000UCA Car Accessory Kit...
VLANS
your router have reset switch just press, then off router and on.
May 29, 2008 | 3Com (3C16593BN) 24-Port Ethernet Hub
Open Questions:
XM Radio XM Direct 2 Mini-Tuner Car Kit for XM Ready Aftermarket Radios  Satellite Logo
46 people viewed this question
Top XM Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a XM Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
