Question about DeLonghi Pac N130HPE 13,000 BTU Portable Air Conditioner with Heat
DeLonghi N130HPE I had the heater on and it appeared to stop heating and there is an error "Le" and next to that is a triangle containing !. This error does not show in manual.
POWER IS ON--LIGHT ON, BUT DOES NOT HEAT UP
Check to see if the heating element has continuity or if it is even receiving power.
Mar 05, 2016 | DeLonghi TRD0715T Oil Filled Radiator...
Dragon 4. Why did it suddenly stop heating?
The heating element may have abruptly failed.
Feb 04, 2016 | DeLonghi Heating & Cooling
How do I get the heating element out of a DeLonghi Electric Oil heater?
many times the sealant they use has to be heated with a torch to remove the element . and if not done properly all the oil in the heater makes a really big mess .
Aug 15, 2015 | DeLonghi Heating & Cooling
Delonghi air conditioner it has a triangle with an exclamation point inside. What does this mean?
There is a knob on the back and bottom of the air conditioner. Twist off the knob and unplug the little black plug and empty the water into a container. I had the same problem and this worked for me.
Jul 17, 2012 | DeLonghi PAC W130 Portable Air Conditioner
Stopped heating up
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Jan 04, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Stopped heating
heatman101
Dec 31, 2010 | Lakewood Oil-Filled Electric Radiator...
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
DeLonghi Pac N130HPE 13,000 BTU Portable Air Conditioner with Heat Logo
57 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
