Question about Pentair Minimax NT Heater
Pentair heater e04
Heater turns on and blows cold air and then shuts off and shows E04. Plus before that it heated up for 4 hrs and stopped when it got to 71, y ?
    Champion:
  • 305 Answers
Fan failure. either issue with air pressure switch, blower isnt producing enough pressure, or blockage within venting
Posted on Mar 17, 2014
5 Suggested Answers
  • 61 Answers
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Posted on Apr 04, 2009
  • 246 Answers
SOURCE: E04 Code on Pentair Mini Max NT
replace valve assembly
Posted on Aug 19, 2009
  • 990 Answers
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Posted on Dec 03, 2009
  • 990 Answers
SOURCE: E04 comes on after fan purge cycle-Pentair minimax nt pool heater
This is a fan falure code. It can mean the fan has problems (not likley if the fan goes and isn't labored) You have a sensor in your exaust (probally not this if you don't get a good start) The culperet is probally in the negetive pressure sensor. This is a 2-3 inch disc with wires going to the controls and a rubber tube going to the fan. Pull the tube from the fan and make sure the fan fitting is clear (poke with a tooth pic) Be sure their are no kinks in the hose. If the heater is 4 years old the diaprahm could be bad in the pressure sensor. Check the other things first but this is probally your problem. Good luck, hope this helped.
Posted on Jan 26, 2010
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
Since you said you replaced the fan, and flow valve. Did you re-install the pressure switch correctly? it will look something like attached image. This is more than likely the cause if you did not replace with the fan or reinstall correctly... or it might have been the cause in the first place...
I have a Pentair pool heater. E04 code
should be the coolant fan thats in front of the raidiator
May 07, 2010 | 2005 Mazda Tribute
Dec 03, 2009 | Pentair Minimax NT Heater
Have a Minimax NT heater that was giving an E04 error. It was able to clear the error when I shut power off and on again. Got the error again then thet heater would trip the circuit breaker in the breaker...
e04 is just a signal that you have not flame clean the burners firs check the conectors . is t blower on ? see if all the hoses are conected wire loose or missibg conector. some thing is making the heater not to work and t tsensor is telling not flame
Sep 16, 2009 | Pentair Minimax NT Heater
Mar 20, 2009 | Pentair Minimax NT Heater
Heater starts and then stops.
I will keep you posted. I have aquired all the service manuals and I am in the process of taking the heater apart. It is not the motherboard.
Mar 09, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Minimax NT Heater Logo
557 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
