Electrical outlet I have a box with two switches for two ceiling lights. One is never used and I want to replace it with an electrical outlet. How do I wire it. and the whites are joinded together and the blacks a running between the two switches. The green to ground.
  • 45 Answers
The blacks running together for the 2 switches should be powered all the time. Connect them to the brass colored screw of the outlet. The whites that are connected together also must go to the silver screw of the outlet. You'd probably want to make pigtails of both the black and white wires to make the connections cleaner.
Posted on Dec 30, 2013
4 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: I have just purchased a
hi thanks for the question the white wire is common the red & black are live join the red & black with a wire nut now you have really 2 wires thanks the appliance doc
Posted on Sep 27, 2008
  • 587 Answers
SOURCE: I am replacing the a/c
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Posted on Apr 28, 2009
  • 394 Answers
SOURCE: I installed Minka remote controlled
The connections you need to make are
Motor to Receiver Electrical Connections: Connect the WHITE wire from the fan to the WHITE wire marked "TO MOTOR N" from the Receiver. Connect the BLACK wire from the fan to the BLACK wire marked "TO MOTOR L" from the Receiver. Connect the BLUE wire from the fan to the BLUE wire marked "For Light" from the Receiver. NOTE: If your ceiling fan features an UP Light: Connect the ORANGE wire from the fan to the ORANGE wire marked "For Up Light" from the Receiver. Otherwise disregard this step and proceed to secure all wire connections with the plastic wire nuts provided.
Orange wire is for the up light, blue wire is for the main light. If you have no place for the orange wire you probably have the wrong remote unit for the light.
Posted on Jan 25, 2011
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
How to wire in an on-off switch for ceiling light from power source going to living room.
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Sep 20, 2014 | Electric Electrical Supplies
I want to replace a ceiling light fixture with a ceiling fan/light combo. the existing fixture is about 32 inches from a wall. what size fan can I put there?
I have replaced a couple ceiling light fixtures with ceiling fan/light combos in bedrooms where the light was basically in the center of the room. This was fairly straight forward and for me required replacing the electrical box that the light fixture was using with a heavier duty fan mounting box which you should make sure you use (that way the fan/light combo won't fall on your head later on -- literally). As far as the size of fan you can put there depends on whether the fan mounting electrical box can be mounted in the "exact" position of your original ceiling light fixture. I say this because the new box MUST be anchored to the ceiling joist structure in some way as a ceiling fan (usually) weighs more than a light fixture and tends to vibrate lending to more stress on the electrical box it's mounted to. Have someone who is an electrician or at the very least has a clear understanding of the importance of proper electrical work do the work or at least clearly explain what you need in your specific situation.
It is generally accepted that you should have at least 18" of space between a wall and the tip of your fan blade. In order to do this with the 32" figure you gave, ideally you should have a (32" - 18") x 2 = 28" fan. A fan in the 28" to 30" range is probably about as big as you should go in this area. You could technically place a 60" fan in that location and leave only about 2" of space between the fan blade and the wall, but that's asking for trouble and should NOT be done in my opinion. The smaller the fan, the less air you will be able to move, therefore you need to balance size, air flow requirements, and the restrictions of your particular location with what you can put there.
Do a quick internet search on "what size ceiling fan do I need" for more information on this topic.
May 26, 2014 | Computers & Internet
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
Replacing a switch outlet combination with a switch GFCI outlet combination and there is only one cable in the box (14/3)
If it worked before, it should be a wire to wire replacement. You are replacing a regular switch/outlet with another switch/outlet which just happens to be a GFI outlet.
Wire the old switch wires to the new switch and the old outlet wires to the new outlet.
Cut the breaker/s off first !!
Sep 25, 2017 | Cooper Industries Electrical Supplies
Hello, I have a ceiling light fixture however there is nowhere I can install it on my ceiling. I have decided to run a wire from the light fixture along the ceiling to the wall and down to an electrical...
What you want to do is against the National
Electrical Code & unsafe
Install a proper box in the ceiling for the
light fixture
Never use exposed cords
Jun 29, 2011 | Hammering
Diagramed instructions of how to use an existing 110 outlet and make another outlet/lightswitch
http://waterheatertimer.org/images/lights-400.jpg
The link above shows basic wiring plan for adding a switch
The switch always turns the Hot wire on-and-off.
When selecting wire size, use same size that connects to plug
So if plug has a yellow-sheathed cable, then use #12 wire
If plug has white sheathed cable, use #14 wire
#14 is smaller wire than #12
http://waterheatertimer.org/RomexC.html
The link above shows how to install wires in octagon box
Your light fixture always attaches to octagon box.
Octagon box can be round, it can be made of plastic.
The box can be nailed to any surface.
http://waterheatertimer.org/Install-owb.html
The link above shows how to add a switch box in existing wall
They also sell octagon boxes that insert into existing wall or ceiling.
http://waterheatertimer.org/How-to-twist-electric-wire.html
The link above shows some basic electrical techniques and
links to wire nuts and wire size
Oct 31, 2010 | Garden
I am installing a receptacle and a light switch in the same box how do i wire it
Hello GWarren,
If you already have the supply current coming into the present box, then you will first, make sure the power is turned "OFF" at the breaker panel before doing any work on this circuit.
Once the power is off, you would then run the supply, (incoming power line) to the bottom screws of the receptacle (outlet). the Black (Hot or Common) wire goes to the brass colored screw, while the White (Neutral) wire, goes onto the silver colored screw. Hook up the bare copper (Ground) wire to the Green grounding screw on the outle.
Now, you have power going to the outlet. For the light switch, it (I'm assuming) will control a light, either on the ceiling or wall mounted ones, etc. In order to do that, you would run another wire, typically #14/2 Awg with a ground, from the switch/outlet box to the bow where the light to be controlled by the switch, is located.
You will need to then connect a short piece of Black wire, about 8" long, from the outlet's brass colored screw (use the one without another wire connected to it, or double up with an existing wire, making sure they are both snug and secure). This should go to the BOTTOM of the light switch with the switch (look for "OFF" on the toggle, or see the metal strap for the proper orientation of the switch for determining which end is up!)
Now, the wires that go to the switched light: Take the white wire FROM the light and connect it to the white screw on the outlet. Now take the Black wire from the light location and connect it to the TOP of the light switch. Take the ground wire from the light location and connect it to the light switch AND over to the outlet ground. (If this is in a Metal box, you also have to attach the Ground wire to the metal box using a Green colored grounding screw, per Code requirements). As a Licensed Master Electrician, you should verify that your application meets the local requirements and codes, based on your location, as each part of the country has some special quirks to installations, based on their experiences. For instance, in Chicago, IL, you have to wrap electrical tape around all the device (outlets & switches, etc.) before they can be approved for installing into electrical boxes.
Please remember, there are several ways to accomplish the type of wiring you are looking to accomplish, and getting it done really depends on where your supply electricity is presently located (at the outlet/switch box or at the llight fixture, etc).
I would strongly suggest that you visit your local library and check out a Bacis Wiring Book, (or you can buy one at Home Depot or Lowes) so you better understand how to best wire your devices so they are done correctly, and most importantly, safely! If in doubt, ask a follow up quesions
You now have a constantly "live" outlet and have taken off power to control the switch that will operate your light fixture or device.
Here's some wiring drawings that might help you with your situation, as it covers 4 variations.
http://www.indepthinfo.com/wire-switch/
Again, if you have any doubts, please comment back and if possible, provide some photos of the electrical boxes you have and I'll try to help you figure it out!
Hope you find this Very Helpful and best regards!
Dec 04, 2009 | Leviton MFG 041-05226-00I ELECTRICAL...
No outlet box in ceiling, it has a hook is there a special bracket, my home was built in the 1940s and the ceiling fan in the kitchen was hung with a hookin the ceiling, there is no electrical outlet in...
They sell brackets at home stores, but I have nailed a 2x4 between ceiling joists & mounted an electrical box at proper height. If you aren't good with electrical, get an electrican to run power for you.
The hanger must be SOLID & the wiring GOOD.
Apr 25, 2009 | Hampton Bay 42 In. Antique Brass...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
