Basic house wiring diagrams
I have two light switches in one box. wired for two light fixtures. I want to remove one switch and make it an outlet. how is this wired?
  • 10,291 Answers
Most likely you can't unless there is a neutral wire in the box too. The wires going to the switch cannot be connected directly to an outlet because there is not a complete circuit for an outlet.
Posted on Jan 05, 2014
  • 415 Answers
SOURCE: I installed a ceiling fan
Here is a Link to EnergyStar's Choosing & Installing a Ceiling Fan. It provides detailed wiring information that should prove to be very helpful to you. :-)
Posted on May 04, 2010
  • 3074 Answers
SOURCE: The Hampton Bay has a
The green wire is ground, the white is neutral, and the black it hot. I really do not understand the question, as the pull chain for the light switch is black and usually there is like blue wire for the lighting kit( which is marked light) as the light sits under the fan housing. The power is wired up top black to black , white to white, and green to ground. Unless you are using two switches one for the light and the other for the fan. I hope this helped Tim
Posted on Oct 24, 2010
  • 13 Answers
SOURCE: i have a two wire
well if you want to control the oulet with the switch yes you can , by running a jumper from the switch load side wich is on the top of the switch and has the leters off to the hot side of the receptacle but if the receptacle is hot from a diferent source or circuit you will need to disable that hot wire from the receptacle to be able to control it with the switch.......
Posted on Jan 14, 2011
  • 3640 Answers
SOURCE: The light fixture needed to
if its a duel switch that controls lights, and the fan seperately. sounds like the power for the lights is going directly to the fan, and therefore making the lights work also. also check out switch, make sure power is only going to the lights, with light switch on.
Posted on May 01, 2011
  • 4736 Answers
SOURCE: on the hampton bay remote
Unfortunately, Mark it's really not as simple as it sounds, to connect the wires properly. Because of that third red traveler wire for the 3-way switch. Actually, ceiling fans don't work well, when a 3-way switch is involved, because it was designed only for lighting convenience. When the fan is turned on, the other ceiling lights will start to glow, whether they are ON or not..
You would be much better served if you can locate another line to come off of and wire to that. Of course,y you won't have the convenience of a wall switch to operate it. But, that's what the pull chains on the fan are for.
Hope this helped you and thanks for choosing FixYa.
Posted on Sep 04, 2011
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Wiring Diagram
Are you replacing 3-way switch?
EJ351 is single pole
You have to test these wires to see what each one does.
Two of the black-white wires will be Hot from breaker box... other wires will go to lights or forward to another switch or outlet box
The black hot wire will connect to one of the wires on timer....
The hot wire will also feed into the black wires that go forward to other switches and outlet boxes.
http://waterheatertimer.org/Basic-house-wiring.html
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Water Heater Timers Save Money
Jun 11, 2015 | Hardware & Accessories
Living room wiring. All the outlets and the bright overhead light fixture are all wired to a wall switch, so you can't have any side lamps on without the overhead light. How do I understand this so I can...
The most common way the houses are wired is through the ceiling. The power comes into the box that the light is on. The power is wired to the light on one wire and the other goes down to the switch. The return comes back from the switch and connects to the light. What the did was connect the wire that feeds the outlets to the switch.
Aug 16, 2014 | Electrical Supplies
Why is the light switch not working after i have wired up ceiling light
check to make sure you have all the white (neutral wires connected as well as the wire to the fixture. Make sure both wires from the fixture are connected to the wires in the light outlet box. White to white(maybe more than 1 in the light box) to the white (common) of the fixture an a different color (usually black or red) to the black from the fixture. Connect ground to ground wire or metal box. Turn the circuit breaker back on, if you turned it off, and turn on the switch. If this doesn't help it is time to get someone who can operate a multi-meter and understands electrical troubleshooting.
Jun 28, 2014 | Electrical Supplies
Inside wiring diagram for 2001 34 foot Golden Falcon Park Model
Request the wiring diagram from the manufacturer.
Oct 27, 2017 | RVs
Light switch wiring
Yes.
The code is maximum 12 boxes per circuit breaker.
You can connect a 12-2 NM W/G cable to one of the outlets. Black-to-black and white-to-white and ground-to-ground. Black is hot, white is neutral, and ground is ground. And bring that cable into a hollow-wall box you install 50" high on the wall. Then run the 12-2 cable up to your light fixture.
http://waterheatertimer.org/images/GE-15312-single-a-300.jpg
http://waterheatertimer.org/OWB1.html
You can also replace one of the outlets with a combo switch-outlet. The run singe 12-2 cable up to light.
This wiring diagram shows half way down how-to-wire-switches page.
Outlets have wide blade on neutral side, and narrow blade on hot side.
The black hot wires from old outlet connect to side of combo device with narrow blade.
The white neutrals from old outlet, and new wire going to switch, all connect to silver screw on wide-blade side of new combo device.
The black wire going to new light connects to screw next to switch located on wide-blade side of device.
Aug 28, 2012 | Electrical Supplies
New fixture installation
Fixture is not identified.
Usually each light fixture is held in place with 2 screws -or- a center nut.
Remove old light and you can see 2 wire nuts covering black wire and white wire, and possibly another wire nut covering green wire or bare copper.
Untwist wire nuts.
Attach new light fixture wires same way as old was removed.
Make sure black wire goes to black wire on light. White to white, green to bare copper.
Copy and paste following links to see basic wire nut, and single-pole and 3-way switch wiring:
http://waterheatertimer.org/How-to-select-right-wire-nut.html
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
Jun 05, 2012 | Home
Diagramed instructions of how to use an existing 110 outlet and make another outlet/lightswitch
http://waterheatertimer.org/images/lights-400.jpg
The link above shows basic wiring plan for adding a switch
The switch always turns the Hot wire on-and-off.
When selecting wire size, use same size that connects to plug
So if plug has a yellow-sheathed cable, then use #12 wire
If plug has white sheathed cable, use #14 wire
#14 is smaller wire than #12
http://waterheatertimer.org/RomexC.html
The link above shows how to install wires in octagon box
Your light fixture always attaches to octagon box.
Octagon box can be round, it can be made of plastic.
The box can be nailed to any surface.
http://waterheatertimer.org/Install-owb.html
The link above shows how to add a switch box in existing wall
They also sell octagon boxes that insert into existing wall or ceiling.
http://waterheatertimer.org/How-to-twist-electric-wire.html
The link above shows some basic electrical techniques and
links to wire nuts and wire size
Oct 31, 2010 | Garden
Should a twoway room fixture actually be a three way ?!?!
The leviton 5603 switch described in the header is a three way wall switch.
I think what you are asking about is what electricians refer to as a "three way switch"
This is basically one outlet or device connected to two wall switches. 1) switch, 2) outlet or light fixture, and 3) another wall switch, three components, thus a three way switch. Installing or converting a fixture or outlet from standard to three way is something i would recommend contracting out to a licensed electrician. Unless you are really comfortable with electrical work.
It is a possibility that your wall outlets are already set up to be a three way switch. A lot of houses have this feature especially at the top and bottom of a stairway, depending on when your house was built. If it is not already configured it could mean stringing new wire behind the drywall which most often means tearing some of the drywall out so that it can be stapled to the studs and meet required building codes.
If, before the changes were made, you were able to turn on the light from either of the wall switches then you will only need to connect the wiring correctly at each of the components.
If you google 3-way switch you will find a ton of great info and wiring diagrams that will help you see exactly what goes into making them work, since they can be wired more than one way. It could help you decide whether or not it is a job you want to tackle on your own or if you want to hire a contractor.
Let me know if I didn't explain something clearly.
Mar 01, 2010 | Leviton 5603-wh 3 Way Decora Switch
I have a live 2-wire line that used to be connected to a light with a switch built into the light fixture. I removed the fixture and put wire nuts on the live wire. What I'm trying to do is to wire the 2...
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
Oct 17, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
