Question about Vinci Mv Unlocked Phone Tablet vm-5610 -
How to open vinci 5610 back cover
How to install sim card
I have lenovo ideapad a10 where do I insert the sim card I see no slot for it
To Install the SIM card:
1)Open the device back cover from the bottom left in direction of the arrow, insert the SIM card to the correct card slot
To remove the SIM card:
1)Open the device back cover from the bottom left in direction of the arrow, press and hold the front of the SIM card, and flip it out slightly.
How to install and remove the SIM card Lenovo A10 70 Tablet Lenovo Support...
Dec 21, 2015 | Lenovo Computers & Internet
How can i remove my sim card to my nokia c7?
The SIM card is located beneath the battery pack. You must release the back cover latch, lift it up, remove the battery pack, and, then, access the SIM card slot. Please, refer to pages #8 and #9 of your phone's user guide (which you can download from this location, in case you happen to miss it) for further details.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 11, 2011 | Nokia C7 (8 GB) Smartphone
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
How do I install the sim card?
To install your sim card.
  1. Open the battery cover of the phone,
  2. Remove the battery of the phone,
  3. then you install the sim card in the direction that is shown on the silver panel under the battery.
  4. Reverse the process to cover the phone back, but do not uninstall the sim card.
take care
Jun 18, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Where to put the sim card
Open the back cover of the phone, remove the battery,slip the sim card into the slot designed for the sim card. Later, install the battery,put back cover. Turn power on. That's it.
Dec 31, 2009 | LG HD4000
How do I replace a SIM card in a Nokia 2115i?
firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
Dec 30, 2009 | Nokia 2115i
Sim Card
Here is a nokia 5610 manual.
open and click on getting started and it shows the sim install.
Nokia 5610 manual click here
if this helps you please leave a vote in fixya
May 17, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Insert sim card
If you want to insert your sim card into your mobile, open the back cover, remover the battery and insert the sim into the slot provided. Put back the battery, close the back cover and then use the mobile.
Nov 01, 2008 | Nokia 6300 Cellular Phone
Vinci Mv Unlocked Phone Tablet vm-5610 - Logo
19 people viewed this question
Top Vinci Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Vinci Cell Phone Expert? Answer questions, earn points and help others
