Question about Manual Transmission
Car starts won't move when in gear
I just bought a 2000 civic manual trans within 2 miles the car stopped moving you can go through the gears and nothing happens
    Problem Solver:
  • 6 Answers
Do you have a burning smell? It could be your clutch, worn out and not making contact with your transmission. Need to drop the transmission and install a NEW clutch, "Matched set". Good Luck
Posted on Dec 30, 2013
Nissan maxima 2000 not moving when in drive D but can move in gear 1 or 2.
This seems to be a clogged filter in trans. Only to be serviced by a transmission repairman or local oil change shop . Beware of some discount trans. Shops , remember they are in the Business ......
Jun 11, 2017 | Nissan Cars & Trucks
2000 ranger 4 cyl. Auto transmission won't take off in drive. Put in 2 and it goes and shifts when I move selector. If you stop you have to put in 2 to start off.
hmmm sounds like first gear is ruined inside the trans if your having to put it in second gear to start rolling may want to have your trans checked out by a mechanic
Feb 23, 2017 | Ford Ranger Cars & Trucks
2000 ford focus manual trans wont operate.
sounds like the new clutch has failed bud
Oct 06, 2014 | 2000 Ford Focus
Car won t move in any gear
Did you also replace the pressure plate? Pilot bearing? If you replaced the clutch...and the car moved, and then stopped moving again...your issue is likely right there, bad pressure plate, flywheel may need resurfaced or replaced ETC. I am curious to know what the old clutch disc looked like when you took it out. Was it glazed or worn? I would pull the tranny again, and look at the new disc to see if it is glazed looking from slipping...and note if it is both sides, or one side, and which side...plate side or flywheel side. If you didn't replace the pressure plate/pilot bearing with the clutch disc...I would do that.
Mar 21, 2014 | Honda Cars & Trucks
Manual trans goes in gear but car won't move
think you will need to replace clutch as it sounds like the lining has broken up on the friction plate
Dec 31, 2013 | 2000 Honda Civic
2000 civic wont drive
Sounds to me that you might have lost your pressure plate or the throw out bearing. The only way to check is to pull your trans out and see if the presure plate is broke or the throw out bearing id gone. Sorry no quick fix on this one. It;s not a bad job to change the clutch assem. but it is time consuming.
Dec 04, 2012 | 2000 Honda Civic
My 1998 Honda civic ex won't move but the motor
Have you just replaced the clutch? Taken out the transaxle, and put it back in? Are you sure transmission was in good condition before this? If so, review your procedure carefully to be sure you got it all back right.
Watch the slave cylinder while someone depresses clutch. You should see the little plunger move slightly out and move the clutch lever back. The lever moves the release bearing inside bell housing into contact with the pressure plate. If slave cylinder doesn't move at all, try bleeding again. The plunger has to move when clutch is engaged.
I'm not sure what you mean by "will shift but won't go into gear". You mean it's actually going into a gear position and car won't move? Or it won't go into any gear, period. As if you had no clutch?
Nov 06, 2011 | 1998 Honda Civic
Not going into gear
have you checked your brake lights? are they working? most cars have a safety feature that require a signal from brake lights (by stepping on brake pedal) to activate a relay to disengage the shifter interlock, OR can you move the gear selector into gear, and it just won't move? is it an automatic or stick shift ? If it's an automatic start the car, after it has ran for 5 - 10 minutes check the trans fluid dipstick, it should have fluid level between add / full marks , if not add or remove fluid as necessary. If is a manual trans, it is possible the clutch is bad. need more info on vehicle, how many miles? engine size?
May 31, 2009 | 2000 Hyundai Elantra
Trans stops working after a few miles
1. where is the transmission control module located..............
2. and where is the shift solenoid located....................
Dec 14, 2008 | 1994 Honda Civic
Manual Transmission Logo
55 people viewed this question
Top Corsa Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Corsa Vehicle Part and Accessory Expert? Answer questions, earn points and help others
