Question about Black & Decker SpaceMaker ODC325 Coffee Maker
I have a spacemaker that leeks at resover
How do I fix this
  • 29 Answers
Used/Cannibaliized Replacement parts for ODC 325 B&D Spacemaker Coffee Makers are regularly sold on eBay, including the entire water reservoir or even the water valve in bottom of the reservoir (the leaky old one can be pushed out from the inside of the reservoir, and a non-leaking used replacement valve can be pressed in in its place).I sometimes buy an old broken ODC 325 cheaply on eBay as a source of parts.
Posted on May 08, 2014
  • Steve May 09, 2014
    There are two cosmetically different versions of the ODC 325, one with door hidng the water reservoir and one without the small plactic door. If you have the version with the door, here for sale on-line is replacement water reservoir complete with the water valve which leaks on your coffee maker.http://www.zibbet.com/LaurasLastDitch/ar...
I have a Rover 75 03 model with sun roof. 2017 I had a leak passenger front I had that fixed, now I have a leek drivers side the same sort of leek I have forgotten what the problem was last time ?
Check the rubber molding around the door. Look for any type of uneven or worn area. Are you getting any wind noise thru the door while driving? Also make certain that the door closes tightly.
Apr 02, 2018 | Rover Cars & Trucks
How to resove the error message "system does not minimum requirement to install this driver" while installing window xp 32-bit drivers on 64-bit notebook(thosiba-C640-11N)?
maybe your notebook is not compatible for xp64 bit try to upgrade in win7 x86 that's much better :))
dont worry on your file it will not be deleted unless you delete your partition. the folder name is "windows.old" that is the folder where save your old files from xp
Apr 01, 2012 | Computers & Internet
Over heating , antifreeze leeking from that water
If your water pump is leaking from the water pump for sure that is causing your over heating problem. I am sure that most likely the seal is gone. There is a main seal in the pump, and those are normally the first to go, and you are better off replacing the whole pump, that trying to fix it. Once your water pump is replaced , the over heating problem should be fixed. If pump is leaking it does not have the pressure provided to have the antifreeze and water to flow correctly through engine block and radiator.
Thanks Mike
Sep 12, 2011 | 2002 GMC Sonoma Extended Cab
Why microsoft excel can not continue the process of opening?
I would try to intall the disk and follow all directions during the insulation. If this fails to fix the problem, try to connect with Microsoft online and advise them of problem you are having, they may take control of your computer and resove the problem or give you direction of what you need to do to correct the problem
Feb 07, 2011 | Microsoft Computers & Internet
1996 couger oil filter housing is leaking
Whipe all the area around cleen, fill the oil level, start the engine and see where is leeking.
If its oil filter gascet leeking, change the oilfilter, clean all htat area and see if it still leeks.
If leek is somewhere else, you may consider asking for help in car service.
Jan 01, 2011 | 1996 Mercury Cougar XR7
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Refrigerator leeks water underneath when it
There is a pan under the the refrigerator that is to catch the water and let it evaporate from the heat from the compressor. The pan may have a hole in it or the little hose is not draining the water into the pan. This should be an easy fix.
Best of luck I hope this helps you:)
Apr 19, 2010 | GE Refrigerators
Coolent leeking and cooling fans mot working
you need to locate leak coolant fan not going to come on if coolant low because the coolant make the coolant sensors tell computer to turn on fans at 190.F.sensor has to be in coolant.it act as a thermostat.you need to fix leak.or you will have engine damage.
May 14, 2009 | 2002 Mazda Tribute
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
131 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
