Question about Sport & Outdoor - Others
Triad viewloader fires but you have to **** the gun every shot
5 Suggested Answers
  • 131 Answers
SOURCE: I rebuilt my NR93AC3 because the old body cracked.
is it leaking out the trigger or the top?
Thanks,
Jeff
Posted on Jan 15, 2010
  • 15 Answers
SOURCE: I attempted to put a car stock on my Tippmann 98
Check the O rings on the big metal striker, make sure that you have the spring on the back (where the stock would have went) in the right hole on the back plate. Make sure that your velocity is set to a reasonable level.
Posted on Jan 03, 2011
robhryn
SOURCE: I have a duo fast SureShot 764 nail gun that won't depressurize after a shot is fired and the driver stays stuck out?
are you putting lubricating oil in the gun? it sounds like its very dry inside . but only a few drops in to the gun at a time, per manufactures recomendations, and only use the approved oil for that gun
Posted on Oct 06, 2012
  • 7 Answers
SOURCE: I fire the gun and it doesnt wanna stay cocked i
make sure to check all the seals(o-rings) on the internals, power tube etc.. also check the seal on top of your c02 tank and make sure its all oiled well.. sounds to me like theres a seal gone inside the gun.. that would be my first guess
Posted on Feb 22, 2013
Modern ammo for it- 32 Colt short
Contact a local gun lovers shop.
May 18, 2016 | Optics
What is a blowback airsoft gun?
Blowback Airsoft Guns are Airsoft weapons that seem much the same as true firearms, since genuine firearms, well some, are secured in a Blowback layer of paint or something to that effect.
The entire slide on the gun with re-cock itself consequently after every shot then generally in the wake of shooting the complete cut after the last shot the slide stays open. The main issue with these airsoft guns is they will consume through your gas. CO2 or green gas both can have blowback.
Jan 14, 2013 | Sport & Outdoor - Others
Www.dewalt.com
Worn trigger valve orings will cause gun to fire twice, and /or attempting to single fire nail with bump-fire trigger. Easy test, look closely at firing pin under trigger. It should fit snuggly an not move from side to side in valve. If loose, replace valve. If your nailer has bump-fire trigger, do no attempt to place gun then fire one shot because the gun will most likely double fire. Good luck.
Oct 09, 2012 | Porter Cable Coil Roofing Nailer
Oct 06, 2012 | Tools & Hardware - Others
I have a 243 cal single shot that snaped when fired. Tried different ammo. still misfires
Firing pin is worn. It may make a slight dent in the primer, but not quite enough to press against the anvil inside of the primer, hence the misfiring
Talk to a gunsmith to see if he has any spares, or has the ability to repair the firing pin.
Oct 03, 2012 | Harrington & Richardson H&R Sportster in...
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Nov 14, 2011 | Hitachi NR90AE Full Round Head Framing...
We cannot get the scope to zero in
you may have a faulty scope,,so,,,clamp your rifle into a jig so it cant move about first,,,then bore sight it,,,without moving it test fire it and set the scope up to were the shot hit, ,fire it again the shot should hit the same spot or very close to it, if it keeps moving about mark were the cross is pointing jam the gun down and fire it off a fuw times if its still jumping around its your scope,,go buy a new one? but you must jam the gun so it cant move about,,,,
Nov 27, 2010 | Tasco WC 416X40 MBLK TADWC416X40
My gun just beeps when i pull the trigger even when hooked up to hpa.battery is new.last time i used the gun just before it messed up i had it hooked to o2 and it would fire then beep ,i have a anti syphon...
You have probably messed up your solenoid, did you fire the marker straight up with the o2? I would make sure that all of the board settings are back to factory default especially the dwell and reattempt with compressed air. If the marker is still not firing get your hands on a new solenoid for it.
Sep 09, 2010 | Smart Parts Shocker NXT Paintball Gun
Sport & Outdoor - Others Logo
100 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
