Question about Fisher and Paykel Aquasmart wl80t65c
Error 27 Fisher and Paykel
Hi, I have this problem on my fathers w/m. I used to be a repairer for F&P but my diagnostic manual doesn't have this model.It is pushing the cold valve on fill, but like everything electronic this doesn't point to the direct fault. Thanks Matt.
  • Fisher and P... Expert
  • 554 Answers
27. (00011011) Fabric Softener Valve Fault
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the fabric softener valve (with Yellow Clip) is faulty. The most likely cause is that
the valve harness has not been connected correctly or the valve is open circuit. See fault
code 49 for service procedure.
Posted on Dec 31, 2013
SOURCE: Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Posted on Jan 13, 2009
SOURCE: Slow fill on cold water/Fisher&Paykel GWL11
Assuming you have already done what you said you have done, now it is time to do some real troubleshooting.(Dont worry, if you have gone this far you'll be able to do what I'm going to tell you)
First take the lid off. To do this, open it, and lift up on one side, it should come right off. Now take the control panel cover off. There are two screws on the back side of the washer holding it on. You'll need to wiggle it a bit to get it off. Once the cover is off you should find a plastic bag with a "service" sheet in it. The service sheet explain how to put the machine into the "Test Mode". This is very easy to do and will allow you to check out all functions. One of the test, allows you to check the cold water inlet valve. Assuming your water pressure is good and you have indeed cleaned the screen filter going into the machine you will most likely find that the cold water valve is not opening all the way and will need to be replaced. If your handy with a phillips screwdriver you only have two more screws to take out and the valve assembly will come right out.
Don't think you can swap out the hot water valve with the cold water valve. Fisher Paykel, clever as they are made sure you can't do that. One is a proportional valve and the other is a digital valve. They both look identical but they are not!
If your going to do the repair yourself (you've come this far, why not see it through to conclusion), be sure when you call Fisher/Paykel to order the cold water inlet valve that you give them the serial number of your machine to be sure you get the correct part.
Good Luck!
Posted on Jan 27, 2009
stephanos18
  • 144 Answers
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Posted on Mar 25, 2009
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Posted on Jul 20, 2009
  • 41 Answers
SOURCE: MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Posted on Jan 31, 2010
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Hi I have a F & P washing machine GW612. It has the seventh light come up in diagnostic mode. Is that error 2 & how do i fix it please? Thanks
Here is the instructions manual which contains the detailed diagnostic code explanations from p.33 on.
http://laundry.manualsonline.com/manuals/mfg/fisher_paykel/gw612.html
Aug 26, 2015 | Fisher and Paykel Washing Machines
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 49 on fisher and paykel 8kg aqua smart washing machine, model number: wl80t65cw1. What does this mean?
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
May 15, 2011 | Fisher and Paykel Washing Machines
Have an eco washer gwl 10. worked fine for years today stopped wokring. tried all trouble shooting and diagnostics. always coming up error code 43. replaced switch and no different. any idea?
Hi there
Try bridging the switch out(join the wires together) and if that doesnt work you may have to replace your motor controller module.
I hope this helps.
Nick
Aug 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel DD603 Service manual
i need a parts manual for a fisher & paykel dw681es wh
Nov 10, 2008 | Fisher and Paykel 23 in. DD603H SS...
Error code 27
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Jun 08, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Aquasmart wl80t65c Logo
78 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
