Question about Craig CMP741d Tablet
Craig cmp741 manual
Locked out forgot password
My craig tablet got locked and I forgot the password ihave no password disk
You must do a factory reset to bypass this lost password.
Jan 25, 2017 | Tablets & eReaders
How do i unlock craig tablet password ?
OOPS sometimes writing down passwords is a good thing
Jan 05, 2015 | Craig CMP741d Tablet
How can I unlock device with the Wifi off?
The default passcode (WEP etc...) is usually on the router. Hopefully he didn't change it.
Sep 26, 2014 | Craig 7 Inch Capacitive Multi-Touch...
How do i unlock my tablet after ive entered too many pattern attempts, and have forgotten my Username(email) Password?
its brand new and you forgot everything already if you did the google mail password assist then open that if dont know that or didnt do it can try provider for assistance and most lockouts are either 1hr or 24hr
Jul 13, 2017 | Craig CMP741d Tablet
Pattern unlock
If this is really the Craig 741d, the only fix to a forgotten password is to erase the tablet and reload the firmware.
View the installation guide and firmware download at http://www.craigelectronics.com/site/pdetails.php?id=411
Feb 09, 2014 | Craig CMP741d Tablet
My craig cmp741e sceen is locked and i forgot password
i need to open my craig sceen its is lock , any help
Mar 01, 2013 | Tablets & eReaders
Need to unlock my craig 741e tablet
I got a Craig 741e (CMP741e), FCC ID AQF-RA-WN11087A with a lost password, stuck on a lock screen, forgotten pattern, no wifi connectivity.
The Craig does NOT support a reset mode, none of the typical combinations of power/volume buttons get you to a restore screen.
The only supported way to restore to default is a firmware restore mode.http://www.craigelectronics.com/site/pdetails.php?id=414 will tell you how to get the firmware file
http://www.craigelectronics.com/firm...irmware4.0.rar
(install instructions: http://www.craigelectronics.com/firm...guide_741e.doc)
HOWEVER! Some CMP741 units will end up stuck on the green Android screen with this version!
If that happens, Craig has supplied a cleaner firmware in case that the first one fails,
http://www.craigelectronics.com/firm....0_cleaner.rar
The name of the core image in that RAR file is sun4i_crane_aihua_20121121, if that gives anyone clues about the system.
Installs the same way - will reboot several times after the firmware install completes, and will fail the first time it runs ("Unfortunately, <process name> has stopped." over and over again). One more reboot will solve that issue.
The Flashing software, PhoenixCard 3.06, is VERY buggy. If would not work with my built multi-card reader on my PC or with an add on-SD card reader on that PC. (could not even see the card). On my laptop, the built in PCI Card reader never recognized the card, but it finally burned the card using the add on card reader. Some people suggest disconnecting ALL USB peripherals before burning. Also, I found if the flash burning failed over and over, sometime a reboot caused PhoenixCard to start working again.
Dec 31, 2012 | Tablets & eReaders
I forgot my password on my craig android tablet
This solution works for most tablets.
Power off the tablet
Tap Power, then press and hold Power + Vol Down until you get a menu, then release
Look for a Recovery or Factory Reset option, and select it.*PLEASE NOTE THIS WILL ERASE ALL DATA, INCLUDING THE PASSWORD*
Dec 29, 2012 | Craig CMP741d Tablet
My tablet is locked n idk how to unlock it its a craig tablet model cmp741x
I put a password on my Craig though screen tablet befor it turns on and I for got it how can I by pass it and open it?
Oct 09, 2012 | Tablets & eReaders
How to unlock my craig tablet, forgotten password
my craig is lock, an i need it to open, any help
Dec 28, 2011 | Tablets & eReaders
Craig CMP741d Tablet Logo
18 people viewed this question
Top Craig Tablets & eReaders Experts
Lawrence Oravetz
mukhtar21 shaikh
mukhtar21 shaikh
David Payne
David Payne
Are you a Craig Tablet and eReader Expert? Answer questions, earn points and help others
