Sony kdsr60xbr1 problems
I purchased in 2006,I Had Optical Block fixed 2009,Lamp replaced 2011, Fan replaced July 2013,Now when I turn TV on green light comes on then red light starts flashing and a grinding-clinking sounds starts like its trying to do something! (no picture)
    New Friend:
  • 3 Answers
Hi, since 2006, you have replaced many parts, why don't you try replacing your TV with new advanced model. Your all problems will automatically fixed
Posted on Dec 30, 2013
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
ginko
  • 19396 Answers
SOURCE: Green light flashing-tv will not reset-no picture no sound
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 21, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
wiqi546
  • 1511 Answers
SOURCE: red light flashing 5 times of kdsr60xbr1
Hello and Welcome to Fixya,
Here are the reasons for which the light blinks 5 times:
If Led blinks 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
Check all possibilities one by one. If nothing works out. You might need to have a replacement.
Do rate my solution, If this helps you out.
Regards.
Posted on Jan 18, 2010
SOURCE: My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Posted on May 19, 2010
I had the lamp my Sony Bravia X2 replaced last nov 2011. Ithasbeen lots of green andredcolors in tv programs and have tried to change the color barson remote etc butpictures still aren't right. Its or
Unfortunately, this is a very common issue with Sony rear-projection televisions. The optical block fails, causing discoloration, usually blue or green. There was a class-action lawsuit which ended in 2009 regarding many Sony models, including the Bravia X2.
It can't be repaired, at least not for a reasonable amount of money.
The silver lining here is that as recently as 2011, Sony was offering discounts on brand new TVs, to people who called in with their "green blob" issues. It's worth a shot, give Sony a ring at 1-888-476-6972
Nov 09, 2012 | Televison & Video
I have a sony kds 55A2000 and my lamp went out so i replaced it. and it startes up fan goes on and off . and tv shuts down light still blinks red? My optical block is getting a light green yellow tint but...
Lamp Fan should not cut off and on it should run at all times when TV is Turned on.Lamp Fan is designed to run when set is turned on to Keep Lamp Cool otherwise Lamp will burn up.
Yes Bad optical unit block could also cause set to shut down.But most of them will Play but with Dots,Green yellow tinit or Big blue Spots
Jun 23, 2011 | Sony KDS55A2000 55" HDTV
Stanby light flashes green and looses the signal tv turns to stanby then comes back on this happens about every 10 minutes
For the KDSR60XBR1, 5 blinks, pause, 5 blinks, etc. means "Lamp driver error" and the probable cause listed is "Lamp driver is faulty".
You may purchase the lamp driver (power supply block), part number 146893612, for $161.86 at http://servicesales.sel.sony.com/web/productSearch.do. Use the Part or Accessory Number to look it up."
Jan 25, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
My sony kds-50a2000 picture is green why? I replaced projection lamp the picture was great but now the picture is terrible everthing seems to have a yellow tinge to it and green seems to be dominant...
The problem is the optical block and nothing else but. Contact the dealer from which you purchased the set to see if you qualify for Sony's extended warranty on this very, very expensive part, which may be covered by a class action lawsuit Check here http://esupport.sony.com/US/perl/news-item.pl?news_id=367&mdl=KDS60A2020 The lawsuit covers all the KDS models. It seems that Sony continued making these rear projections even though it knew the optical block failed prematurely. When you get it fixed, go to setup and make sure the cooling fan is on HIGH and power saving is ON. Both of those features will extend your TV's life, including the optical block and the projection lamp. Further, bring a portable compressed air tank to the TV and, with a narrow nozzle, empty it into every opening in the set's back. At least once per month, check for dust settling on the rear of the stand behind the TV -- when it gets thick, get the air tank.
May 10, 2010 | Sony KDS-50A2000 50" HDTV
Sony KDSR60XBR1 had lamp replaced march 09 then optical box replaced june 09 2 months or so after i turned the tv on and the picture looks like **** from all inputs. I did everything tech support asked me...
The Optical Blocks have been major problems in this Model Line. As far as I know they are still covering the cost to replace the Optical Block out of the original warranty that came with the set. Most of the issues with the Optical Block is either micro dust build up in the light path, (mirror, LCD panels, etc),
or a heat issue causing failure on one of the LCD panels with in the Optical Block.
As far as the Lamp is concerned, they will fail on average every 3000 to 5000 hrs of use.
I am not sure if I answered your questions but hope I did.
Skyassoc
Dec 27, 2009 | Sony KDS-R50XBR1 50" HDTV
I have a red band at topand a blue band at bottom of the screen of my 50inch Sony Bravia KDF 50E2000 rear projection TV. Cany sugestions as to how to resolve this or what is causing the problem?
Your TV has a bad optical block. Mine has the same problem. Sony has extended the warranty on the optical block till 6-30-2010. I called Sony and they offered me a newer model 52 inch flat panel LCD for $450 and told me to keep the old TV. They will also pay to have your TV repaired if desired. Here is the email I recieved from Sony:
Dear Valued Sony Customer,
Models: KDF-42E2000, KDF-46E2000, KDF-50E2000, and KDF-55E2000
US Based Customers: KF-42E200A and KF-50E200A
As part of the Sony commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor), in the United States, on the optical block of the above-referenced 2006 model Micro-Display Rear Projection televisions until June 30, 2010, regardless of purchase date. For any customer who requires repair of the optical block on one of the affected models, Sony will cover the cost of the optical block repair (parts and labor) at no charge through June 30, 2010. This extended warranty does not apply to the replaceable projection lamp or the other parts that may be used in the televisions.
Sony is also announcing that for any owner of these model televisions who paid out-of-pocket expenses on or before February 28, 2009 for an estimate or repair service to replace the optical block, Sony will reimburse the customer by mail for the cost of the optical block and the labor expense to replace it, subject to certain conditions. To receive reimbursement, please follow completely the directions on the claim form; for reimbursement all claims must be postmarked by April 15, 2009. See the claim form for complete terms and conditions.
All other terms of the Sony limited warranty continue to apply. Sony utilizes a network of hundreds of qualified independent third-party servicers to perform in-home television warranty service. Sony, through its authorized servicer network, will endeavor to repair your set within 30 days of your first contact. For diagnosis, warranty service, or if you are not provided a repair within 30 days, please contact Sony at (888) 649-7669.
Sincerely,
Sony Electronics
You received this email because our records show you registered an eligible Sony product. This is a one-time customer notice and will not impact your status with regards to other Sony emails, nor will it result in additional emails.
If you have not subscribed to Sony Style updates and would like to do so, please click here.
If you would prefer not to receive further email communications from Sony Electronics, please click here.
Or send an email to unsubscribe_sony-ctg0aib7gaab2lyq6eyzcveybhkian5q@sel.sony.com.
If you'd like to update your email address with Sony Electronics, please click here.
Sony Electronics Inc.
Personal Information Management Office
1 Sony Drive, MD 1E4
Park Ridge, NJ 07656
© 2009 Sony Electronics Inc. All rights reserved. Reproduction in whole or in part without written permission is prohibited.
Privacy Policy/Your California Privacy Rights | Legal/Trademark Dear Valued Sony Customer,
Sincerely,
Sony Electronics
Jun 06, 2009 | Sony KDF-50E2000 50" HDTV
Loud Fan Noise
This is a free repair on the optical block/engine. For specifically a road mapping issue. (Where there is sparactic grouped lines on the screen of the TV)
Otherwise there is a full recall on all 50XBR1's and 60XBR1's for ANY video issue.
But the bullentin I do have on that is Confidential due to the amount of claims SONY could recieve. But here is a sample of the bulletin.
Models: KDSR50XBR1, KDSR60XBR1
Subject: Optical Block: Warranty Policy and Part matrix by serial number.
Resolution: As part of Sony’s commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor) for optical block replacements on the models listed above until October 31, 2008, regardless of purchase date. Authorized servicers should follow the normal process for warranty claims for this issue.
Dec 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
Top Televison & Video Experts
