Question about Saeco Starbucks Sirena Espresso Machine
Double shot won't work, single does
When I try to pull the double shot, machine gurgles a little then teh blue light comes on as if the pump is not primed. Have primed repeatedly to no avail. The single shot works perfectly. Any ideas?
  • virginiashir May 20, 2009
    Decided that I think I can fix it by de-scaling the machine with lemon juice. If all else fails, read the owner's manual - ha ha ha.
    President:
  • 1,618 Answers
Try using without the portafilter, if it works then the problem is in the grind or the pressure used to tamp the coffee.
Posted on May 31, 2009
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
Lights on, motor running, does not do single/double shots
There is a tiny plastic one-way valve in the brass tube on the pump under the top cover that get calcified and stuck when not in use. I used a toothpick to get it out after disassembling the pump and its hoses. Slowly and carefully lay out your parts to reassemble the springs and washers correctly.
Oct 14, 2009 | Estro Barista Athena
Starbucks sirena won't heat up; blue light flashing-brand new
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 27, 2009 | Saeco Starbucks Sirena Espresso Machine
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Aug 02, 2009 | Solis Crema SL-70 Espresso Machine
Starbucks Sirena. lights blink, won't heat.
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
The filter basket on my FrancisFrancis X5 sticks to the machine.
Place a glass under the filter basket. Do not return the portafilter. Pull another shot. The pressure will push the filter basket off.
Apr 01, 2009 | FrancisFrancis! X5 Espresso Machine
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
Water flow
You will have to adjust your shot timing, and possibly your grind. To program the shot timing, hold the Brew Stop button until all of the brew lights come on; That means all of the buttons are ready to program. Next, pull some grind for your portafilter and push the button you want to program. For a single, you want to pull a 1 oz shot in about 15-20 seconds; longer for a double. When you push the button, the shot will start to pull; when the shot is complete, push the button again to set it. Then do the same for the next button. Each group needs to be programed separately. Holding the the Brew Stop button again will turn out the remaining lights and save your programming to that point. As to the grind, you want to have the grind fine enough to give you a quality shot in the right amount of time. Good Luck!
Oct 13, 2007 | Astra Mega II Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
239 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
