Question about LG 50PS11 50 in TV
Lg 50ps11-ub does not turn on
I have a lg 50ps11-ub and the red light just stays on the tv will not turn on i have changed out the 2 centre boards when you plug it in and turn it on theres a little hum noise but thats it
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
  • 133 Answers
SOURCE: LG 42 plasma power problem
needs power supply Part number 6709900023A
it is a 171 dollar part, you should be able to order through LG,
Posted on Jan 10, 2009
  • 257 Answers
SOURCE: LG 50px4dr plasma tv turns off immediately after
The problem could come from the power supply at the first suspected one. If you have a knowledge of trouble shooting, open the cover then examine if any caps there look poping up. Use your finger touch on the top of caps you will feel it. If not, check all the fuses there then disconnect all the cables from power sup to other boards, except the main board. Check Va and Vs according to the label attached on the back of panel. If the power sup shut down, replace it with a new one. Hope it helps.
Posted on Aug 12, 2009
  • 8457 Answers
SOURCE: lg 50 in clicks but won't stay on.
Ur power board need it replaced,LED indicator light not sustaning power.
Posted on Jan 05, 2010
itvrepair
  • 28 Answers
SOURCE: my lg plasma tv stays on standby
is you already change the power board,is possible
your y board is out...is a big board on the left side of the tv
Posted on May 19, 2010
I have a lg 50" plasma tv with a distorted, discoloration. The model number is 50ps11-ub. Not sure what circuit board/panel to purchase. Can you help me with this? Thanks
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 27, 2016 | LG Televison & Video
Why is my lg plasma tv top half screen black?
electronic board fault , usually cracked solder joint see the liink below for more details
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 31, 2016 | LG 50PS11 50 in TV
I turn on my tv LG 42LE5350-UB I can see red light on front but does not turn on no audio and image can not see, what can I do?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 12, 2015 | LG Televison & Video
LG 42LC2D-UB TIVO Remote Stopped Working
Hi Did you check the batteries,and if they're put in properly.
Make sure you have fresh batteries and not 2 different kinds. then do your codes again. Good luck.
Feb 11, 2014 | LG 42LC2D 42 in. LCD HDTV
LG 42LC7D-UB after few minutes the sound goes off and channel change by itself
When heats up, the supply voltage from the main power supply board goes less. Check all the soldering to this board for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. If it do not help you, replace the board as card basis.
Jan 09, 2013 | LG 42LC7D-UB Television
My LG 50PJ350-UB PLASMA TV DOES'NT TURN ON BUT MAKES A TURNING ON NOISE
check for bad capacitor in the power supply board and then check shorted component parts at the sustain board.
Aug 30, 2012 | LG Televison & Video
No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Dec 27, 2009 | LG 42LC7D-UB Television
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Cuts off
Most likely the power supply board.
Lie the tv down on a bed and unscrew the back. Its only about 9 screws around the edge and look at the power board, on the left, see if theres any burn marks.
I have a brand new board I bought the other day for the same issue but before I replaced it, stupidly, I checked with LG and turns out mine is still under warranty so I'm stuck with a new board.
Let me know if you want it. I'll match any price you can find online.
Mar 20, 2009 | LG 42LC7D-UB Television
LG 50PS11 50 in TV Logo
93 people viewed this question
