Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Can I add fluid to rear tires w/o hurting rear end.
Hello: I have just purchased a Husqvarna Lawn tractor model 2754 GLS with hydrostatic tranmission. I believe the trany is made by Tuff Torq and is a heavy duty trany. My question is can I add fluid to the rear tires w/o harming the transaxle? John
  • jmont54 May 19, 2009
    Thank you.
    John
    Sniper:
  • 57 Answers
Adding fluid to the tires should not affect the transmission at all.
Posted on May 19, 2009
  • Diamond57 Jul 13, 2011
    Adding fluid to the tires will void any existing warranty on the transmission.
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
Rear wheels are locked
Hydrostatic or not, whats your model #. If it is Hydrostatic, first! MAKE SURE YOU ARE ON FLAT GROUND before you pull the bypass lever on the transaxle. Check your manual, if not I have included a link that may help. http://www.husqvarna.com/ddoc/HUSO/HUSO2008_AAaa/HUSO2008_AAaa_YTH2246_532418529.pdf Check out page !!
Apr 09, 2014 | Craftsman 20 hp 42" Lawn Tractor
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
Husqvarna Riding mower wont reverse gth2350 riding mower
I think theres 2 flow paths forward and reverse try checking the fluid level you may have to lower the rear end out of the machine or most all ridders ive seen allow you to take the backing plate off and then block the rear tires off the ground the fluid level should be about and inch from the top of the threads... if yours has a resivor off to the side with a breather fill it to the bottom of the threads... now that the fluid is full and up on blocks or jack stands start the engine and at an idle put it all the way forward to flush the bubles out this has to be done in small chunks 5 minutes forward and then laiter go 10 back let sit for 20 minutes in between and check the fluid level a couple of times to see if it whent down from this... best of luck hope this helped
Oct 03, 2012 | Husqvarna "GTH24V52LS 52"" Kawasaki 726cc...
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Jul 28, 2012 | Poulan Garden
My drive belt for my Husqvarna 2754 GLS has slipped off. The mower blades work, but it won't go forward or reverse. It doesn't look broken. I have checked all levers and trany switchs.
sounds like the belt has come off the from the the tension idlers
that are on the clutch brake arm bracket 1 wil be a flat idler and 1 will be a vee idler these 2 place tension on the belt for drive
and when clutched no tension is placed on it
there is also 1 more pulley in the drive line other than pto take off
it is about the middle and is a flat idler
please check website below for part diagram
http://www.partstree.com/parts/?lc=husqvarna&mh=29
select 2754 gls 2008
and go drive system
drive line and belt route will be shown
save a copy fyi
cheers hope it helps
paul
Aug 11, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Jul 21, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
438 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
