Question about Garden
What is the gas and oil mixture for a 142-e series husq
2 Suggested Answers
joboo1
  • 257 Answers
SOURCE: what is the gas and oil mixture ratio
Hi, McCulloch chain saws have different mixtures depending on whether you use their brand or generic and is also dependent on the model. The three mixes are 32:1, 40:1 or 50:1. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little. If you see any coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
Posted on Feb 23, 2009
I have a Husqvarna 142 chainsaw. The saw will idle, however when I depress the throttle the saw chokes down a dies.
What condition is your spark plug in?Is your filter clean?Is your gas-oil mixture correct? Is your gas fresh?Is your brake releasing?Is the blade and chain on correct?
Nov 21, 2016 | Husqvarna Garden
How much oil and what type of oil should I use in the trimmer?
You use no oil,use regular unleaded gas only,on 4-Cycle engine use gas,2-Cycle engines use the oil- gas mixture,your's is better cause you just need gas.I use Husq's too.
Apr 13, 2016 | Husqvarna 224L 25cc 4-Cycle Straight Shaft...
My mom has Husq 125BT backpack leaf blower, the blower runs ok once it gets started but after about 15 minutes it shuts off and is extremely hot, what causes that and what do i need to do to fix it?
sounds as though she is not using the correct oil to gas mixture OR she is using two cycle oil that is for outboard engines not air cooled engines.
Nov 28, 2015 | Garden
I added 0.4 oz of oil to 1/2 gallon of gas too much to mixture. How can I dilute the mixture without starting over?
??? Take a gallon gas can, pour the I/2 gallon oil/gas mixture into it and then add the correct amount of undiluted gasoline to the correct mixture. For instance, if you need a .2 oz/I/2 gal ratio then add 1/2 gal gas to what you already have. Remember, it is always better to have a little too much oil than gas.
Jul 30, 2014 | Husqvarna Weed Eater 26 In Deck 190 CC...
I have a husq/136 chain saw 2002 replaced oil ppump and pich up tube it still pumps to much oil on chain
this can happen when the two plates are missing that go on each side of the blade, or there is a oil adjust screw that controls output of oil, but lots of oil is a good thing as long as it last a tank of gas, if not it can be a bad thing !
Nov 07, 2013 | Husqvarna Garden
NEED OIL GAS MIXTURE FOR A HUSQ.36
Hi WDBLACK43...
You will use a 50 to 1 ratio
1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Sep 23, 2011 | Garden
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I am borrowing my friends brand new Husqvarna 142 which has never been used and she cannot find her owner's manual. What is the oil to gas ratio?
That should be a 50:1 gas to oil ratio. Just make should the measurements are concise, and that your fuel mixture is well mixed. If anything you,d prefer to err on the side of a little tto much oil rather than not enough.
If it is brand new, I'd suggest runninit at about half speed for a minute or three, then moving on up to about 3/4 for another minute.
When you go to cut, rev the engine up to a fairly high speed before putting the saw to the wood. In most cases, you want to let the weight of the saw do most of the cutting, versus bearing down on the sae. Yhat puts undue strain on it, sepecially for a used saw. Try not to allow the saw to "bog" down, so the engine speed drops considerably while cutting.
Sirwriter
May 17, 2009 | Husqvarna Garden
Fuel/oil mixture
3.2 oz oil in one US gallon yields 40:1 mixture.
2.6 oz oil in one US gallon yields 50:1 mixture.
Jan 15, 2009 | Humminbird 140c Fishin' Buddy
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
