Question about Brother HL-2070N Laser Printer
Paper feed mechanism
I always manual feed the paper because using the tray has never worked. But now it says "No Paper fed Tray 1". I have a Mac OS X. Don't know how to tell it to feed manually or from tray.
Soulvisitor
  • 1113 Answers
SOURCE: paper won't feed
I replace feed rollers when this happens but you guys might want to try a slighty damp rag on the probally covered in paper dust feed roller.
Location underneath with cassette out.
Appearence larger Black Rubber cresent shaped roller inch wide front middle under.
Use damp rag water/metho
Posted on Dec 20, 2007
SOURCE: Brother MFC-8440 shows "manual feed" and will not feed from tray
Press "Job Cancel".
Posted on Feb 04, 2009
darck_teck
  • 22 Answers
SOURCE: My Brother MFC 9440cn keeps giving a paper jam
try seting the paper to A4 not leter
Posted on Jan 04, 2010
pranam
  • 23 Answers
SOURCE: manual feed paper
that's easy thing, you should right click on printer icon and in property, check that option, you will find that optop paper feed, change it from manualy to automatic.
Posted on Jul 11, 2010
SOURCE: Forces manual feed of paper whenever printing WordPerfect doc
Is a WordPerfect problem.
In WordPerfect go to file/page setup/select letter (or whatever)/edit/source - set to auto select.
Problem solved!
Posted on Dec 02, 2010
Tray 1 doesn't feed while tray 2 has paper, after I empty the paper from tray 2, tray 1 work fine.
if you setup tray 1 any type, any size and tray 2 to plain, and letter size, it will allow you to use tray 2 for your plain letter jobs but will pull from the manual feed tray first only if the paper is in the manual feed tray if this makes any sense to you... please mark this as a fixya...
Nov 24, 2013 | HP LaserJet P4015N Printer
Our infoprint 1125 is on a ibm mid range computer system & is accessible to 9 users. when we print an envelope, the printer asks for a manual load of the envelope, how do i change this to automatic...
It's been my experience with these machines that envelopes are always fed through the manual feed tray.
The Tray 2 cassette's pick up assembly is different than the manual feed,
it has 2 rollers that have a wide area they can pick up while the manual feed has just 1 single roller.
If you remove the tray cassette and look under the printer you can see the two rollers, these would probably have a hard time picking up a standard size envelope.
Also the tray would have to path the paper up and would have to bend it through the paper path which can cause problems with the flaps on the envelopes.
Best method is to use the manual feed tray and to also have the back cover open so that the envelopes path straight through the printer without being curled.
(I've seen these in a ton of places ranging from small business to banks and they always have the envelopes in the manual feed)
Jun 08, 2011 | IBM Infoprint 1125 Laser Printer
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Keeps saying no paper in tray although paper is in tray
I encounter that problem before, after I checked the sensors, feed unit and mechanism nothing is wrong or broken but still NO PAPER indicates on the display .I only noticed with the machine is the cassette tray or the paper tray, when you try to pullout the cassette tray and look at its left side, there is missing parts on it. There is a spring and actuator on it that will engage on the feed unit drive. Try to find the same machine and look at the cassette tray to see the missing parts on it. You can buy a new cassette because the parts that is missing maybe not available.
Feb 19, 2009 | Brother DCP-8065DN Black and White Copier
Paper tray won't feed paper & I get a false paper Jam code
This might work for you - it worked for me. HP paper was feeding crooked. Checked the "Paper Type/Quality" in the printing options window - mine was set to Photo Paper. When I changed it to Plain Paper, the paper fed evenly. Hope this works for you.
Oct 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Card Stock is Not Fed from the Bypass Tray
Check the inside of the printer, ensure that there is no paper or foreign object stuck, sometimes they go undetected and they can affect normal printer feeding.
Try pulling out the paper tray and check the paper feeding mechanics underneath the printer.
Usually feeding problems are mechanic, if you cannot fix them in this simple way you will need to take printer apart and check feeding traction mechanics, this is usually a job that is better done at a repair shop.
Aug 11, 2008 | Ricoh Aficio CL2000N Laser Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Brother HL-2070N Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
