Question about Intex Pool & Spa
Want to know how to recharge a poolscape sand filter
Inside the sand filter, there is a dividing wall with a fill line marked on it. is this where to fill with sand or water?
    Sergeant:
  • 286 Answers
The fill line for sand,, there should be water in the whole thing when running and no air..
Posted on Jun 12, 2016
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
  • 6 Answers
SOURCE: Sand from the filter is getting into the pool.
u are getting sand in to your pool most likely because u have a broken lateral i nthe bottom of your filter.
Posted on Jun 09, 2009
jharwell668
  • 640 Answers
SOURCE: How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Posted on May 24, 2010
john224
  • 1378 Answers
SOURCE: Sand leaks into pool. I took apart the vari-flo
Thank you for posting your question here on Fixya.com.
You need to empty the sand out and replace the lateral assembly too. It attached to the bottom of the valve and has several 'fingers' embedded in the sand. Once it wears enough, the sand can get thru it. Replace the sand if it is over 3 years old while you are at it. A wet/dry vacuum works well for removing the sand.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 13, 2010
john224
  • 1378 Answers
SOURCE: I have a hayward sand
Fill it half-way with water, cover the stand pipe coming up in the middle so sand cannot get into it, fill the tank with the sand (only use the amount the label says the unit takes), then install the valve and piping.
John
Posted on Jun 01, 2011
How do you replace sand in filter
get the amount shown on label of filter take off top shop vac all sand out you should have a spacer to keep standpipe straight and to keep sand out of it if you dont just eyeball the center and put a rag inside pipe to keep sand out fill with sand then put top back on
Jul 19, 2014 | Sta Rite Pool & Spa
How do you know if your hayward s 200 is not running right
sand in your pool is a sign that you may have damage inside your sand filter. it is not uncommon for laterals to break during winter months. also, as the sand wears, it becomes smaller and may pass through.
remember that the filter sand is white. if you have sand in the pool that doesnt look like filter sand, you may have a problem with a broken line back to pool. keep an eye on your water level as you will lose water with this scenario
May 07, 2014 | Hayward Pool & Spa
Hayward s166t sand filter has sand in sight glass during backwash
did you get sand in vertical tube if so it will take time to get out of line
Jun 12, 2012 | Hayward S166T Pool Filter System w1 HP...
I don't know how to vacuume me pool. I have a hayward sand filter
all you need is a pole, a vacuum hose, and a vacuum head. connect the hose to the vacuum head and the head to the pole. Submerge the vacuum head and the pole into the pool and push the vacuum hose slowly straight down so that it fills with water. Once the entire vacuum hose is filled with water, plug it into the skimmer suction or wall port. You may have to adjust the valves at the pump to increase suction to wherever you have to vacuum hose plugged in to.
Hope this helps
Aug 01, 2011 | Hayward SAND FILTER, PRO SERIES
I have an older Hayward pool filter. Is there a link to dowload instructions for replacing or adding sand to the filter?
Here is how I do it. Open the top. Open the drain on the bottom to allow the water out. Remove the plastic water difusser on the top. With a small can, scoop out the sand. When you get to the laterals, remove them for inspection. The sand below the laterals if fine, it does not need to be removed. Put the plug back in. Replace any laterals that may be broken (probably none) Fill the filter with water to about 6 inches above the laterals ... maybe more. The water will protect the laterals from the new sand as you fill the filter. It will also help the sand to pack in around the laterals. Continue filling until you are about 3 inches below the difusser that will go on the top. Make sure you don't bury the little black hose. The purpose of the little black hose is to remove the air from the filter during operation. The hose should ultimately stick up into the inside of the top (cover). I think your filter takes about 300 # of sand. Double check with your professional pool supplier where you purchase your sand. I normally will fill the filter with water before I replace the top. You may want to put on a new "O" ring too ...
This new sand should last you at least 4 to 5 years in non commercial use. After that time, you may want to replace the top 4 inches with new sand.
Thanks for your question @ FixYa.com
Jul 06, 2011 | Hayward SAND FILTER, PRO SERIES
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
Removed all old sand from filter put new sand in but getting lots of sand in the pool
when removing the old sand, you have to be extremely careful not to break any of laterals at the bottom of the tank. Also, when you added the sand, you should have filled the tank with water at least up to the lateral assembly/hub. If you have not broken a lateral and filled the tank with water up to the laterals before adding the new sand, you could have a problem with the multiport valve. Make sure the spider gasket inside is in place and not damaged/deformed. Also make sure the spring is not broken. Those are the only problems you can have with sand returning to the pool.
Sep 15, 2010 | Hayward SAND FILTER, PRO SERIES
Sand leaks into pool. I took apart the vari-flo control valve and found that the rubber that fills the top of the dividers in the piece that has 6 sections in it has eroded and come out. Could this be why...
John
Jun 12, 2010 | Hayward Pro Series 18" Above Ground Pool...
Won't fill with water, water dribbling in.Possieble solenoid problem??
Take off the pressure to the inlet valve or valves by turning off the wall supply
Unscrew the hose connectors making sure that you mark which ones they go back onto if your machine fills both hot and cold
Look inside the opening there will be lots of gung inside , pull out the filters carefully
You may need a pair or long nosed pliers
Wash out the filters and re-assemble
If that does not improve the flow , change the valve
Jun 30, 2009 | Washing Machines
Pool & Spa Logo
156 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
