Question about Canon imageCLASS C2100 Laser Printer
White stripe We used our Canon ImageClass color laser printer for several years. I just replaced the transfer kit (roller and other parts). Now I get a white stripe running vertical on the paper. It is not is the same spot everytime. Any suggestions?
    President:
  • 1,653 Answers
Maje sure tyhat the corona wire is clean (use a dry bristle haired artists paint brush or use the cleaning pad supplied with the printer) and making sure that the toner cart cleaner / scraper is not clogged or has some paper jammed on it. Also you can vacuum the Corona Wire with a domestic vac and the nozzle tool or a clean soft brush tool but make sure the printer is turned off before doing it.
Posted on Aug 30, 2009
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
Canon LBP5200 displaying Error Code E078 What is the problem?
E078 secondary transfer roller drive
mechanism fault
Possiblle causes:
Check the connector of the roller drive sensor.
Check the connector of the roller drive clutch.
Replace the main drive assembly (roller Drive
sensor).
Replace the drum cartridge (roller drive cam).
Replace the DC controller PCB.
Jul 01, 2010 | Laser Canon imageCLASS 8180C Multifunction...
Our Dell 5110cn stopped working and the 'diagnostic' said to replace the transfer roller. I had purchased a Dell Imaging Drum and replaced that. I believe it has a transfer roller as part of the Imaging...
Dell sells the drum & transfer roller a kit, but there are 2 different parts to it, the drum & the transfer roller & they do not look the same. Replacing the drum does NOT replace the transfer roller. We've had a 5110cn for 4 years, I've replace both of these parts & the fuser unit several times.
May 07, 2010 | Dell 5110cn Laser Printer
I have light vertical stripes on a dark picture and dark stripes on lighter colored pirctures. I have cleaned the head about 15 times and it is worse now than before. I am wasting ink and getting nowhere....
Have you checked the maintenance kit? Is the white roller badly contaminated? The mylar blade dirty?
If that is ok, then you may have a bad print head.
Mar 10, 2010 | Xerox Phaser 8400 Laser Printer
There is a white stripe (miising writing) in the middle and in the left side of the printed paper. i have changed the toner, but the problem doesnt solve. maybe its the laser motor dirty? thnx for any help
Problem : white stripe (missing writing) in the middle and in the left side of the printed paper
Printer Laser Printer MF5650
Cause of the problem Dust
Solution Cleaning ..
There could be reasons for your problem
1) The TONER CARTRIDGE not clean - i think you replaced it
2) The Imaging Drum
3) Beam Alignment Lance (glass which reflect the rays)
1) there are toner and the drum
2) take out the Toner cartridge
3) there is a black roller on Toner Unit - clean it with the Cotton
4) Take out the Drum clean it (Don not use water or spirit to clean it )
5) Fuser Unit a Hot Unit the Red Color Roller no need to clean ..
Following Video will show you the over view of the Product
Video 1 use full video help you to understand the whole process
Jan 03, 2010 | Canon LaserBase MF5650 All-In-One Printer
Not printing properly
1 try printing from the adf feeder
2 try printing from the scanning glass
if from one of the above method has the problem try to clean your optics
if streaks comes from both u might have problem with the following parts
the charger unit- service it
the toner cartrigde- try a new one
the transfer roller - its is a black roller of it becomes white replacement is needed.
May 05, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Paper feed broken
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Mar 20, 2008 | Canon ImageClass MF5770 Laser Copier...
Paper wrapped around fuser roller
http://www.precisionroller.com/fuser-assemblies---units-for-canon-imageclass-d780/products.html
im not 100% familiar with this printer but iv replaced ALOT of parts on ALOT of different types of laser printers(color and mono) the fuser invariably will come out either the left or the right side, last place would be the middle. either way they are always fairly easy to get to being they are the second most common part replaced in a laser printer. Tipicly located right by the toner in the paper path. this should be easy to find.. IF you still need help finding it send some pictures with either side taken off or the "hood" up. and ill point it out to you. BE CAREFUL OF the contra wire. it will zap you.. even if the printer is unpluged.
Jan 22, 2008 | Canon imageCLASS D780 All-In-One Laser...
Canon imageCLASS C2100 Laser Printer Logo
107 people viewed this question
old marine
old marine
