Question about Sharp MX-2700N Color Copier
Print to bypass
When I send labels to print to the bypass it doesnt pick up the paper but picks up the paper from a tray. I actually want to print to the bypass
    New Friend:
  • 91 Answers
Before printing click the property button, go to papar tab, under tray select, change from auto select to by pass tray
Posted on May 20, 2009
HP Pro 8500 printer will not feed paper keep getting "load paper" error even though paper in tray; found small white "gear" in tray.
If the gear is broken, you most likely need to replace the pick up roller which is extremely hard or almost impossible. You may try to see if the error is really with the broken gear, or you if you just have a dusty roller that picks up paper by checking if the rollers is actually spinning when it is trying to pick up the paper.
To see what the issue is with gear or roller, try the following:
1. Remove the output paper tray and paper from the loading tray.
2. Send a copy job or print job through.
3. have a flashlight to shine light on the pick up roller and se if it spins. Try touching with your hand to be sure.
4. If the roller spins, put some alcohol on a cloth or paper towel and clean the rubber rollers.
5. Wait a few minutes, load paper and try sending copy job again.
If the roller is not spinning, then you have a problem with gears for sure.
http://www.303electroncs.com/
our eBay parts store: 303Electronics eBay Stores
Mar 30, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
Paper jam when print from tray 2
There is Registration Sensor located near the bypass tray.Please clean the sensor or else replace the sensor or DC board.Orelse please check the pick up roller solenied switch( spounge in solenied may be torn out replace with another spounge)
Apr 05, 2014 | Genuine Konica Minolta Konica Minolta...
Paper feed does not pick up properly
Clean the tray paper feed roller rubber,or try using the bypass tray(manual alimentation).
Apr 22, 2013 | Samsung SCX-4521 All-In-One Laser Printer
The samsung ml 2250 printer doesnt pick up the paper out of the paper cassette. It works someteiimes but mainly the paper is not picked up at all and you hear the noise like it wants to pick it up but cant...
Hi there,Don't think its the clutch. I would rather say its more a problem of the paper not getting pushed up against the pickup rollers so you could try stretching the spring a bit and see if it helps.. What you also could try is removing the tray and bypass the paper sensor and see if when you print the pickup roller does turn.
Regards
Jul 28, 2011 | Samsung (ML2250S3XAA) Paper Cassette for...
How do I print labels, envelopes or any non statement size item? Have tried using bypass and all I get is an error message. I had the people where we bought the machine come back and see if they could get...
Hi, wich kind of error message?
Is it " check paper size" or " paper jam" or ...
Does the paper goes all the way trough copier or jams at bypass, at drum or fixing section,...
Did you "tell" over pc drivers that you are want to print on labels, that the lables are eg. A4, that pick up paper from bypass,...
It could also be a problem in pick up clutch and solenoid, or it just needs to clean the bypass pickup roller,...
Send more info
Jun 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Feb 17, 2009 | Toshiba Estudio 200L Copier
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Sharp MX-2700N Color Copier Logo
390 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
