Question about Mr. Coffee BVMC-KG6 Single Serve Coffee Brewer, Black/Silver
Got this for christmas and it doesn't seem to fill the cup correctly. I tried using the 10 oz and it seem to fill the cup just as much as when I did the 8 oz and at the 8 oz it didn't fill completely. Could it clog already after first cup?
  • 16,166 Answers
Probably not plugged. Those machines use air pressure to move the hot water around. It sounds like there is a leak or bad compressor. Take it back.
Posted on Dec 30, 2013
How many grams are in a cup
Assuming yogurt weighs about as much as water, 1 pint of water weighs about 1 pound (16 oz). Two cups to a pint, so one cup weighs about 8 oz.
Aug 29, 2014 | Kitchen Appliances - Others
Where can I find the measuring cup for Black and Decker Model RC446 part #RC426-30
Using 1 cup of rice to 2 cups water does not result in perfect rice in this rice cooker. The measure cup that comes with the unit is actually 5.5 oz. measurement of dry rice and then you fill the water line accordingly. 5.5 oz of dry ingredients is equal to about 2/3 cup.
Nov 08, 2012 | Black & Decker RC400 7-Cup Rice Cooker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
Wont brew an entire large cup
depending on how large, they fill by oz's..a large mug wont fill to the top..Depending on how strong you want your coffee..you may set for large cup the use same k-cup and the use little setting to double fill....
Dec 18, 2010 | Keurig B50 Coffee Maker
Trying to self-prime like the directions say. Water is coming out extremely slow. How long should it take to fill cup? The steam wand seems to work perfect with plenty of water coming out.
Hi
If you are doing it right and using the double shot filter basket, with the correct amount of coffee, with the right grind and tamp. You should not get anything, for about 5 seconds after you turn the pump on, and it should take between 25 and 35 seconds for an 1 1/2 oz to 2 oz of espresso.
Aug 03, 2009 | Gaggia Baby Espresso Machine
My grind and brew turns itself off in the middle of brew cycle
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Whay is the coffee to water ratio per cup?
I have the Regal 10 to 30 cup model K7030C.
Instructions read as follows:
CUPS COFFEE
(5-oz serving) ( 8-oz dry measure)
10 ........................2/3 Cup
20.........................1 1/4 Cups
30.........................1 3/4 Cups
Hope this helps
Mar 06, 2009 | Regal Ware (RW58230R) 30-Cup Coffee Maker
Lost Cup
The measuring cup for my Rival RC100 holds 6 oz (volume of water to the top rim). The markings on the inside of the pot (1 through 5) seem to hold about 12 oz each.
(that is: the 1 line holds 12.2 oz, the 5 line held 57 ounces of water)
close enough to the standard 2 to 1 water to rice ratio.
I put in about 1.7X as much water (by volume) as brown rice, and it comes out very good for me. (1 cup rice to 1 3/4cup water).
Jan 23, 2008 | Rival RC100 10-Cup Rice Cooker
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Mr. Coffee BVMC-KG6 Single Serve Coffee Brewer, Black/Silver Logo
391 people viewed this question
Top Mr. Coffee Wine & Spirits Experts
ray gallant
RSole
Are you a Mr. Coffee Wine and Spirit Expert? Answer questions, earn points and help others
