Question about Toshiba Satellite P205D-S7479 Notebook
Cannot burn to CD, but it will play CDs and DVDs. Will not recognize a blank CD
My toshiba satellite p205d will not recognize a blank CD. It tells me to insert a blank disk! I used to be able to copy fine, but not now. It plays CDs and DVDs fine, but will not let me data transfer. I've tried all of the suggestions on the toshiba help site, nothing works. I'm running vista.
I have just bought a toshiba satellite c650d. Will it play DVD's. It is running on Windows 7 and has 4GB of ram
Toshiba Satellite C650D has a DVD Drive and it is capable of playing DVDs.Certainly, it will play DVD. It even supports High Defination (HD) video. So, ENJOY!
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Feb 03, 2011 | Computers & Internet
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
My HP DVD 740 won't recognize blank CDs
Sounds like the lens is dirty. Run a cd cleaner through the drive. That should take care of it.
Dec 15, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
My Compaq Presario desktop will not burn CDs
Perform a system restore and take the computer back to a time before the problems started with burning, or you can download a different media player and try burning with that, real player as a good bit of software to use for burning and Nero is too (Nero is a devoted burning suite)
Get real player here >>>>>>
http://uk.real.com/realplayer/
Get Nero 9 here >>>>>>
http://9-burning-rom.com/index.asp?aff=101&camp=gg_nero_uk&se=google
Good luck
Jul 08, 2009 | HP Compaq Presario S4000V (P8655P#ABA) PC...
My Matshita UJDA 750 DVD/CDRW wont recognize a blank DVD discs. How ever it does read both CDs and DVDs and only burns CDs.... please help
Are you trying to burn a dvd? If so from the spec you gave in the problem description your drive will burn cds(CDRW) but will only play dvds(DVD). If it stated DVDRW then you would be able to burn DVDs as in the CDRW.
Mar 06, 2009 | Evesham Voyager 6400 Notebook
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Lite-on DVD R/W combo LH-20A1L BLO5 Blank discs not recognized
Have you checked device manager to see if you have a yellow checkmark on your DVD./CD drives? if ok, sounds to me like the maker of the LH-20A1l BLO5 either needs to fix your problem or replace it. The Nero 7 should enable it to work correctly.
Feb 14, 2008 | Computers & Internet
CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
Jan 22, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba Satellite P205D-S7479 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
