Question about Bose Lifestyle 18 System
Green light flashing on acoustimass? why?
Have bose lifestyle v10 home theatre system...on acoustimass speaker, there is a green light flashing. why is it flashing? should light be solid?
  • Jeremy Daker
    Jeremy Daker Mar 30, 2014
    Seems like there isn't a legitimate answer....
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Posted on Mar 01, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
Ojelola
  • 22 Answers
SOURCE: no sound from centre speaker
Check your audio settings, via the on-screen menu. The center channel may be turned down. When set at -5 to -8, the center channel speaker may be practically inaudible. If raising the volume of the center channel does not solve the problem, then you do have a dead center channel. The system would then be in need of repair.
Posted on Jan 26, 2010
  • 3 Answers
SOURCE: No display lights on bose lifestyle 8 home
If your capable of replacing components yourself - Change capacitor C19 (33uF 63v) its on the board next to the display.
This cap goes leaky/dry after time, as there is a lot of ripple on it. This is what causes the display to go dim or blank. changing this cap brings the display back on most cases. Also maybe change the other capacitors near it while you are there..
Really works!
Posted on Sep 02, 2010
emissionwiz
  • 76630 Answers
SOURCE: can i see Bose ® Cinemate ® GS Digital Home Cinema Speaker System mainboard
Sorry that type of information is not published on the internet.
Posted on Jan 06, 2017
Where can i find a replacement audio input cable for acoustimass powered speaker system model 2683 5 pin din
See on ebay.com for used or new one of it as other trading sites sell quantities. Such as alibaba or aliexpress for chinese or amazon for better qualities
Feb 27, 2015 | Bose Lifestyle Acoustimass Powered Speaker...
Better sound through bose speakers?
If you have the money to plunk down for a Bose Acoustimass home theater speaker system, I'm sure you will be quite pleased. Of course, as you indicated, appropriate placement of the speakers is important. Still, I'm sure you will find that a properly placed Bose Acoustimass speaker system will fill your room with high quality sound, substantially better than Onkyo's stock speakers placed equally well.
I own a Technics home theater system, which I initially purchased to use in my family room. Yet, when I listened to a Bose Lifestyle system (powered by Bose Acoustimass speakers), I could have nothing less. The Bose system went in the family room, where everyone could enjoy it. I put the Technics system in the bedroom, where it is rarely used.
Jan 09, 2010 | Onkyo HTR500 Receiver
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Please help i have matsui dav50 home cinema dvd player and cannt change it from 2.1 to 5.1
i have Bose - Acoustimass® 20 Powered Speaker System without the lifestyle, can i connect a pre amplify to it
Oct 31, 2009 | Bose Acoustimass 20 System
Jul 28, 2009 | Bose Lifestyle 38 System
Cannot access the System menu on home theatre
for sure call tech support from bose they are very helpfull
Dec 28, 2008 | Bose Lifestyle 18 System
No sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Glad to be of service...
Dec 21, 2008 | Bose Lifestyle 18 System
Bose acoustimass 9
Did bose make a Acoustimass 9 series
Oct 19, 2008 | Bose Lifestyle 40 System
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Sep 11, 2007 | Bose Acoustimass 10 III System
Bose Lifestyle 18 System Logo
1,086 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
