Question about KitchenAid Cooktops
How to dismount KitchenAid cooktop model KECT 365
We cannot remove our KitchenAid KECT 365 electric cooktop from counter to replace its burners. Instruction Sheet (Form 85021 Rev B) shows four mounting brackets and adjustment screws under the counter, but we cannot find either. In theory the cooktop should lift out but it won't budge. We tried to remove the 12 tiny screws holding bottom plate, but some won't move or spin in place. How can we lift out the glass cooktop without using enough force to crack it?
  • 338 Answers
SOURCE: Supporting a ceramic cooktop
Yes. It is. i always feel weary when i see it to however the top is not glass its ceramic so it is a little stronger.if you are in fear wrap tape all the way around the top and tight. if the top is tempered then wrapping the tape around it would make it almost indestructable.
Posted on Nov 26, 2008
tzweeb
  • 318 Answers
SOURCE: I can not separate the glass cooktop from the granite surface.
alot of installers will use a silicone glue to "seal" the unit to the countertop. what happens is that means you cant get it out without cutting the glue off first.
it could also be that the unit is very tight in the countertop.
also did you remove the "hold down" screws from underneath the unit first??? there should be a screw on each side below the unit.
one more thing... do you have a gas line under your counter? if not be sure you can get a gas line to it before you try to remove the old unit. most homes have a finished ceiling under the kitchen and it would be almost impossible to install a new gas line if its not already there.
Posted on Dec 29, 2008
GodBlessU
  • 3513 Answers
SOURCE: Kitchen aid KECC507GBL3 electric 36in cooktop.
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Posted on Jan 14, 2010
heatman101
  • 43501 Answers
SOURCE: We have a kitchenaid cooktop that works great
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Nov 30, 2010
  • 1531 Answers
SOURCE: KitchenAid Electric Cooktop Model KECC507 -- when
sounds as if your fuses are rated to low for the range they should be at least 35 amp fuses
Posted on Oct 10, 2011
How do I remove the blower motor on a Kitchenaid cook top model number kecd866rww01
I think that you have to lift the whole cooktop out and the blower assembly is attached to the bottom.
Installation manual and user manual are here for viewing or download.
KITCHENAID Counter Unit Electric Parts Model KECD866RWW01
Sep 30, 2014 | Cooktops
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
Why not refer this issue directly to KitchenAid. Maybe they can explain the disparity between what the installation sheet shows and what you actually don't see.
Had a spill on my kitchenaid KGCC566RBL gas glass cooktop. some dripped in the knobs and under the glass top. How do I access that to clean?
I found this......
https://www.doityourself.com/stry/how-to-replace-a-glass-cooktop-on-kitchenaid-ranges
I read it and it's on replacing but the top comes out.
Gloves are a good idea too. Cut power at the breaker.
unless easy access to the wiring/plug.
Hope this helps you.
Have a good evening.
Feb 02, 2018 | KitchenAid KGCC566RBL - 5 Burners...
How do I remove knobs for burners to clean them?
To remove the knobs from the cooktop you just pull them off. They are only presser fitted on a post.
Jul 30, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Cooktops Logo
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
