Question about Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
My Kenmore elite HE3T will not unlock and the error code of du blinks on & off and then the f. I have unplugged it, tried to rerun it, try to open the door, and even have unplugged it. It aslo make a "hard clicking" noise every few seconds. Can you help?
    President:
  • 1,865 Answers
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • Posted on May 19, 2009
    DU code for kennmore elite washer
    I have the same problem. I replaced the lock latch and the code still comes up and note I I'm back to square one. Ugh I wish there was a way to disable the dash and reset it.
    Sep 07, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
    Error code " du "
    DU = Door Unlock code
    Washing machine displays error code F/DU after six attempts to unlock.
    -Door lock assembly failed.
    -Test door lock switch
    -Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
    The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
    Hope this helps.
    Jun 22, 2011 | Washing Machines
    Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
    Door unlock failure
    Excessive force on door lid is preventing lock bolt from
    retracting.
    Wash media buildup is preventing lock bolt from retracting.
    Machine/motor control cannot determine if door lid is in an
    unlocked state. See TEST #8, page 14
    Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    I am getting the code on my frontload washer F du, it is making a clicking sound the water starts to fill , then the code comes up..I am not able to find this code in my manual ..I am thinking that maybe...
    The DU in the display is an error code for the door lid not unlocking. This is an indication that the lid lock assembly has failed or the control board is unable to determine if the lid is unlocked. This usually indicates that the lid lock assembly will need to be replaced.
    http://www.servicematters.com/maytag_library/docs/16007803.pdf
    Service manual above.
    Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
    Du error code on whirlpool cabrio
    that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
    if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
    Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore front loading washer
    brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
    Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    DU error code
    liz, DU could mean a couple of things. Something is preventing the lock bolt from retracting or the motor control cannot determine if the door lock is in a unlocked state. With the lid closed put it in a manual test mode by pressing any key except for power, start and stop. With all indicator lights off, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds. If done correctly 88 should appear. While this 88 apears press the same key again within 5 seconds. You are now in the manual test mode. Now go over and press the second rinse or extra rinse key. This key will toggle between lock and unlock. See if the lock assy. is working. To exit the test, just unplug the washer for 60 seconds. If you don't have any luck with the test, you will have to do a bunch of tests on the lock mechanism to determine if in fact that is the problem. If it's under warranty, I would have the service company get into that. Catriver
    Dec 15, 2007 | Kenmore Oasis HE 27082 Top Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    572 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
