Question about Kodak EASYSHARE M763 Digital Camera
How do you take the kodak m763 apart?
I took out the outer screws but it wont pull apart i dont want to pull too hard.
BillB-SA
  • 2761 Answers
SOURCE: I have a Kodak M763. The camara don't want to turn on. Don't work
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 14, 2009
leepania
  • 1099 Answers
SOURCE: my kodak m763 lens wont open. and when i turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new cable.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 03, 2009
BillB-SA
  • 2761 Answers
SOURCE: My Kodak M763 camera won't turn on.
If the camera has recently been dropped you may have lens damage which is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 04, 2009
reitann
  • 214 Answers
SOURCE: Macbook says file type "unrecognizable" from Kodak M763
It seems that your computer doesnt recognize jpeg files . Download or reinstall quicktime to fix the problem, you can get free download at www.apple.com
Posted on Dec 23, 2009
leepania
  • 1099 Answers
SOURCE: My kodak M763 lense is sutck and the camera wont
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Posted on Jan 12, 2010
How does one replace outer door that is cracked?
you will need to open the door, take the screws out of the hinge, take the door off, lay it down on towel on something flat take all of the screws out of the inside of the door, make sure you note the screws when you take them out they will be short ones and lond ones,, then after all screws are took out you can pull it apart,, again take note on how all of the parts are installed,, then just replace the part and reverse the way you took it apart
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
How do I correct the date on my camera, it has the wrong date on my pictures
Press the MENU button, use left/right to highlight Setup, press OK, use up/down to select Date&Time, press OK.
You can view/download the user guide at
http://support.en.kodak.com/app/answers/detail/a_id/18873/kw/m763/selected/true
You can view/download the extended user guide at
http://support.en.kodak.com/app/answers/detail/a_id/18870/kw/m763/related/1/selected/true
Jan 01, 2011 | Kodak EASYSHARE M763 Digital Camera
Need an instruction manual for a kodak easy share m763
User Guide:
Extended User Guide:
Nov 22, 2010 | Kodak Cameras
Hi i have a problem with my digital camera kodak m763
There is nothing you can do to change the quality of the picture you have already taken. But for future pictures please change the resolution within Menu, Camera Settings, picture Quality (it shows stars)
Jan 02, 2010 | Kodak EASYSHARE M763 Digital Camera
Pulled projector apart because it appeared to be getting hot.
There is no way to know what model and the lense arrangement over the phone. what you need to do is contact Kodak archives;they will need the model and perhaps fax to you an exploded diagram that shows the lense position and orientiation. Otherwise, you can contact some older photoshops that used to deal with this stuff and perhaps there will be someone whois still in the business from several years back and can fax you the diagram. Goodluck, Macgivor
Jan 02, 2010 | Kodak Office Equipment & Supplies
Camera wont Turn On
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EASYSHARE M763 Digital Camera
Mar 25, 2009 | Kodak EASYSHARE M763 Digital Camera
Eye piece replacment
I had the sme problem and took it took wolf camera. they would not support it. Soo I used it this way for a year with no problems. The inner LCD craked and and finally bought a new Z712 today for 199.00!
Jan 09, 2008 | Kodak EasyShare Z612 Digital Camera
Kodak EASYSHARE M763 Digital Camera Logo
115 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
