Question about Orange SPV M2000 Pocket PC
SPV M2000 Bluetooth Headset use
I cn pair to my bluetooth headset but don't seem to be able to connect to it. So I can't use it to make or receive calls handsfree.
    Problem Solver:
  • 11 Answers
Re: SPV M2000 Bluetooth Headset use
Go to settings connectivity then bluetooth it should say my devices go there
then turn on your bluetooth headset and click on look for more devices
Posted on Nov 30, 2007
0 characters
3 Points
Bloototh is no working
when you go away from the iphone the headset lose connection with the blueooth and that's normal , but when you coming closer to the iphone the headset will not reconnect again!
until you delete the headset from the bluetooth setting and pair it again.
Ive tried it with two bluetooth headset : Blueant z9 and Soundid sm100 , with both of them i had this problem.
I called apple and they told me to open the airplane mode for a min and shut it , didn't help.
i just can't believe apple release the phone like that even when they will fix it on the next update.
HOW how can i fix my bluetooth wizard in my LG laptop.. it says the file could not be send because the connection could not be can i check that the bluetooth radio is plugged in ?????Configuration: Windows Vista Internet Explorer 7.0
Aug 13, 2010 | Nokia 7710
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
Jan 11, 2010 | LG KU990 Viewty
Bluetooth not accepting anything
The T-Mobile G1 doesn't actually support file transfer through bluetooth :S So it's not faulty, it's just not programmed to do that. Sorry! However it should be able to find your bluetooth headset, it always finds mine. Maybe the headset is faulty?
May 27, 2009 | HTC G1
Bluetooth headset won't pair with Blackberry 7100V
Are both devices turned on and able to be paired - On the blackberry you need to enable Bluetooth before pairing.
You may need to reset the headset and start again, make sure it is flashing to indicate fully charged and on.
Apr 06, 2009 | RIM BlackBerry 7100v Handheld
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Cant pair my bluetooth
To identify where the problem is, try connecting another bluetooth device (like another phone, or a bluetooth headset). The other device will most likely connect. If it does, try contacting the manufacturer of the dongle, they will probably have a simple solution to fix it.
If it does not connect to another device, try deleting the bluetooth devices stored in phone (especially ones you dont use, but you may need to delete more/all depending on the situation) and add then. This fixes connection issues the majority of the time with very little trouble since rebonding what you need later is a simple task.
May 17, 2008 | HTC PPC-6800 Smartphone
Bluetooth wont work
spanner - wheel click!
bluetooth -wheel click!
bluetooth disabled - wheel click!
Enable bluetooth -wheel click!
Paired devices
- wheel click!
Add device - wheel click!
after the search select the device you wish to connect to...& contiue to follow the on screen prompts & pairing instructions.
Dec 18, 2007 | RIM BlackBerry 7290
SPV M2000 Voice Dial ??
voice dial is rubish dont bother only works if the background is quiet anyway
Dec 18, 2007 | Orange SPV M2000 Pocket PC
P990i is not supporting headset bluetooth HBH-PV700
You must operate your bluetooth headset HBH-PV700 in discovery mode in order for your mobile to discover the headset and then pair the two devices. To activate the discovery mode of your headset, while it is switched OFF press the switch on button and leave it pressed for approximately 10 seconds, then search for it with your mobile and pair the devices. most of the times the code needed for pairing is 0000 (zeros)
Oct 03, 2007 | Sony Ericsson P990i Smartphone
Orange SPV M2000 Pocket PC Logo
126 people viewed this question
Top Orange PDAs Experts
Cosma Papouis
Cosma Papouis
William Dehn
William Dehn
Are you an Orange PDA Expert? Answer questions, earn points and help others
