Question about Rolling Code Scrambler
Fuel guage not coming on nissan quest 2004 - Rolling Code Scrambler
  • 55 Answers
Check for recalls they had problems with that
Posted on Jan 23, 2014
Where is the fuel cutoff switch in a 2004 nissan quest? The car is not transferring the gas through the plump. It did yesterday. And now you cannot hear the plump. I just want to turn off the fuel cutoff...
i know that the previous gen quest had the fuel inertia RESET switch on the driver side kick panel...
fuel is cutting off via the ECM for your generation though
"If the engine speed is above 1,800 rpm with no load (for example, in neutral and engine speed over 1,800 rpm) fuel will be cut off after some time. The exact time when the fuel is cut off varies based on engine speed. Fuel cut will operate until the engine speed reaches 1,500 rpm, then fuel cut is cancelled."
http://www.nicoclub.com/FSM/Quest/2004_Quest/ec.pdf
EC 33
do you have trouble codes ?
Mar 03, 2015 | 2004 Nissan Quest
What your trying to change out? A fuel pressure regulator; if so go to your fuse box and see the fuse for your fuel then first turn on your vehicle and then pull out the fuse to the box that will suck up all the remains in the line. Once you open the fuel pressure regulator out slowly and make sure you have some rags around so the little fuel remains will come out and then in stall your regulator if that is what you going to change out. Good lucky and always wear safety glasses????
Nissan van stalls when starting
Turn the the key to run position with cas cap off listen for fuel pump to buzz 3-5 seconds fuel pump keeps system pressurised when off or pressurises quickly when you try to start it. it is very commom for ground wire at the pump to fail with poor connection. When changing these pumps I often disreguard the original connections and carefully solder wire directly to the pump. to be sure you should use a inline fuel guage to test the fuel system accurately
Mar 23, 2013 | 2004 Nissan Quest
I have a leak -looks like transmission fluid- can't find where it is coming from. 2004 nissan quest
put a clean cardboard sheet under the vehicle and keep an eye out for where the leak falls from.. follow up from that spot until you see the fluid itself..sometimes its hard to see but if you use a strong flashlight you may see better..it will look brownish or brownish-red in color..if its black then its motor oil...if its clearer then it may be brake fluid or power steering..
Feb 24, 2013 | 2004 Nissan Quest
Is there an access panel on the 2004 Nissan Quest, one to help me change my fuel pump?
Unfortunately not. You must remove the fuel tank from the vehicle to replace the fuel pump.
May 20, 2011 | 2004 Nissan Quest
How do I know if it is time to change the spark plug for Nissan Quest 2004?
When was the last time the spark plugs where change? A good indicator is to take them out and examine them for corrosion and/or damage. Also, another indicator is poor fuel economy and your vehicle may have a higher than normal idle.
Jan 26, 2011 | 2004 Nissan Quest
2004 Nissan Quest began shaking while driving then
SOUND LIKE FUEL PUMP.SCAN IT TO MAKE SURE.IT ALSO COULD BE FUEL PUMP RELAY OR FUSE.
Aug 10, 2009 | 2004 Nissan Quest
2004 nissan quest idles rough when van is stopped
Have 2004 Nissan Quest. After 40 mph Van runs rough and there is a loud rattleing noise that sounds like an old 4 bbl carb waaaah, but ther is no code
Aug 14, 2008 | 2004 Nissan Quest
Programming nissan Quest Remote control
I have a used Nissan Quest 1999 that Remote Control does not work . How can I program it?
Jun 29, 2008 | 2004 Nissan Quest
Rolling Code Scrambler Logo
24 people viewed this question
Top H10 Vehicle Parts & Accessories Experts
Terry Hair
Lodhi Autos
Lodhi Autos
_-__-___-_
_-__-___-_
Are you a H10 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
