Question about Kenmore Dryers
Kenmore dryer has quit making heat for drying , the dryer functions are all working just no heat.
  • 5,911 Answers
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The first step in troubleshooting this problem would be to check the voltage at the terminal block in the back of the dryer. This is where the dryer cord is installed. You should be reading 220-240 VAC across the two hot (RED & BLACK) leads. Checking the voltage in this manner not only verifies the source voltage, but also verifies the cord is good. CAUTION: Use extreme care when checking the voltage at the terminal block. The terminals are LIVE even when the dryer is shut off. I would recommend unplugging the dryer temporarily to remove the back cover plate over the terminal block to prevent the possibility of electric shock. With the terminal block cover removed, plug the unit back in and take your readings. If the voltage is incorrect, you may have a defective wall receptacle, or a breaker tripped.
NOTE: The dryer will still run with only half the voltage present. This is because the drive motor only utilizes 110-120 VAC to run. The heating circuits require the full 220 in order to work.
Pay particular attention to the section that discusses proper air flow. Most dryer heat related problems are caused by clogged, kinked, or poorly installed exhaust ventilation. A dryer needs proper air flow in order to dry efficiently. If the air flow becomes restricted, the dryer heating circuits will actually overheat to the point of failure. The most common failed item is the thermal cut-out (TCO). This component is designed to blow like a fuse in an overheat condition. Once blown, it must be replaced. You need to check all the heating circuit components in order to rule out multiple component failures, though.
If you determine the TCO to be defective, it is strongly recommended that you replace the hi-limit thermostat at the same time. These two components are often sold as a set. Failure to do so may result in premature failure of any components you replace.
The reason I mention emphasize air flow so much is because if you replace any defective parts, and leave the dryer in a condition where it is starved for air, you will damage those same parts again. So, if you haven't cleaned your dryer exhaust vents any time recently, you may want to do this, first.
If you have questions along the way please let me know. I hope you find this information helpful.
Posted on May 19, 2009
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
Kenmore Elite Clothes Dryer working but not drying
First take dryer vent hose off and check for a plugged vent, clean it all out. There is either a clamp on the hoses you take off by prying or with a screwdriver, should be two one at the dryer and one at the vent to exit the house, also make sure that there is nothing blocking the door on the vent that exits the house sometime animal like to build nests there. If this does not fix the problem it could be the heating element in the dryer, sometimes it is cheaper to just replace the dryer than the element
May 21, 2012 | Kenmore Dryers
An old dryer. Works very well but quit drying clothes. Everything else is working in it but there is no heat to dry the clothes. I would like to fix it myself. Numbers on it are: 697267, 341195, and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jul 18, 2011 | Kenmore Dryers
KENMORE DRYER MODEL# 86880100 SERIAL#M81937120, WHEN ON THERE IS NO HEAT FOR DRYING. THE DRYER SPINS AND MORE DRY FUNCTION HAS NO HEAT,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 12, 2011 | Kenmore Dryers
Dryer won't dry - no heat
Make sure you have 240 volts going in. If you do, then it can only be the heating element or the thermo cut off located on the heater housing. Also could be the thermostat on the housing as well. The heater relay is possible, but check that last, it's most likely the element.
Mar 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Kenmore dryer takes to long to dry
You may have to get inside the exhaust assembly ...somtimes there are lint buildups that occur and cause long drying times. Also make sure you don't have a DUAL heating element model. I had one and only one of the elements worked when I repaired the second one it worked great. Most likely is the exhaust block however. Hope this helps.
Jan 18, 2009 | Kenmore 659 Electric Dryer
Heating Problem
If this is a gas dryer, you probably have bad valve coils, they can work intermittently, usually for the first part of a cycle, but when they heat up the internal resistance gets too high and they fail to open the gas valve. Once they cool off, (by continuing to air dry) they will work again for a few minutes. They will also make a buzzing/rattling (maybe "metal" ) noise as voltage is applied. For any Kenmore gas dryer, get part #279834 it contains both valve coils. Very easy to replace. Another possibility is that your duct work is plugged, check airflow. Hope this helps.
Sep 14, 2008 | Kenmore Dryers
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Dryers Logo
108 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
