Question about Tria Beauty Next Generation 4X Laser Hair Removal for Face & Body - Green -
The light at the bottom its not on
Its not lighting up
Have 98 expedition have top break lights but no bottom break lights. have signal and diving lights but still no break lights on bottom
The circuit for the high mount light does not go thru the turn signal switch. The other brake lights do.
So you would need to check for power in and out of the turn signal switch on the brake circuit.
Mar 05, 2013 | Cars & Trucks
My bottom break light won't work. The top brake light works but neither bottom lights work. I've checked the fuse and replaced both bulbs but they still don't work. When I manually engage the brake pedal...
You may have a problem with the turn signal switch, as power comes out of that switch to power the brake lights, the high mounted brake light does not go through that switch.
Dec 22, 2010 | 2003 Ford Explorer
How to change headlight
theres phillips head screws all around the top and bottom of light, should be two on top two on bottom
remove those and light comes right out
install new light
re install screws
and viola new light
happy motoring
Nov 02, 2010 | 1986 Lincoln Town Car
I have a, 1996 buick regal 3.8 l brake lights on bottom are out ,but brake light in center is on? i replaced brake light switch on pedal,but still bottom lights are out
it is a problem with the multi unit switch. (turn signal switch) It is a 50 dollar part, and involves removing most of the steering column.
Aug 04, 2010 | 1996 Buick Regal Olympic Gold
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Upper reverse lights light, bottom two don't
Are there bulbs in the bottom two and is there a hole cut out for sockets in the bottom?
I know some cars have more than one set of lights, as they are made universal for all over the world. Example, Santa Fe has lower fog lights in the bumper, but these are duds in North America as it's just a housing. In UK these lights actually have holds cut into them with sockets, bulbs and wiring.
Aug 17, 2009 | 2002 Buick Park Avenue
Just prchased panasonic 14.4v drill/driver, charging battery, the top light and ver bottom light come on but the third light from the top, "battery now charging" light does not come on.
yes, worked it out, it was a legend of the bottom lights` status. they wern`t lights that were supposed to come on.. a bit embarrassing actually.. too many years using bad tools.. lol.
Mar 23, 2009 | Panasonic 14.4V Lithium Ion Drill Driver...
Trying to set time on nike watch
1. Press the bottom left button(MODE) to put on Time mode.
2. Press the LIGHT button (ADJUST/LIGHT) for three seconds.
3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds.
4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down.
5. Press the LIGHT button to finish.
Mar 13, 2009 | Nike Watches
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Tria Beauty Next Generation 4X Laser Hair Removal for Face & Body - Green - Logo
67 people viewed this question
Top Tria Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Tria Health and Beauty Expert? Answer questions, earn points and help others
