Question about Motorola DCP-501 Receiver
My dvd player on the reciever is not working how to i fix it
I have a toshia sd1810 dvd player that no matter what dvd I put in it tells me incorrect disc. How do I fix this? My dvd player is on level surface with nothing ontop of it. I have all the cables hooked...
Many times, the laser in the DVD players burn out over time... but it could have a hair or something on it. Try cleaning the laser with a DVD lens cleaner first. They make them and they look just like a DVD but they have little brushes on the disc to brush off the lens. If it still won't recognize any disc, it's probably time to get a new one.
Oct 09, 2010 | Toshiba SD-1810 DVD Player
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
Dvd player turns disk slowly and gives wrong disk message..won't play
Are there any scratches on the cd? If there aren't. then you might want to bring in your dvd player to the service that you recieved it from and get it fixed.
Jul 01, 2009 | Lasonic PDL-305 Portable DVD Player
Can't hookup this DVD Player to the Directtv HD DVR receiver
red and white leads go from dvd to reciever,yellow goes from dvd to the tv
Apr 30, 2009 | Televison & Video
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My trutech tt320 dvd player isn't responding to anything. the blue light indicates that it is on, however, the tv recieves no signal from the dvd player. is there anything i can do to fix this, or is it...
I had the same problem. I took it apart and found a blown capacitor on the power board. It was a 10v 1000Uf high temp. capacitor. I replaced it with a new one and the dvd player worked fine. The capacitor can be ordered for a couple bucks and replace easily if you know how to solder.
Dec 29, 2008 | TruTech TT320
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
NOT RECIEVING SOUND FROM ALL SPEAKERS WHEN PLAYING CD/DVDS
CANNONT RECIEVE SOUND FROM THE FRONT N REAR SPEAKERS WHEN PLAYING A CD/DVD. THE RADIO AUTOMATICALLY PLAYS THROUGHTOUT THE CAR. WHEN SRC DVD/CD IS SELECTED NO SOUND EMERGES. SO I PUT ON THE DUAL ZONE. AND THE ONLY WAY TO HAVE SOUND IS TO HAVE ONE ZONE TUNER, AND THE OTHER DVD. WHEN I REVERSE THEM OF COURSE THE SOUND WILL SHIFT EITHER FRONT OR BACK. IF U CAN HELP ME FIX THIS AND RECIEVE SOUND FROM ALL SPEAKERS WHILE CD/DVD anPLAYING I WILL APPRECIATE IT. THIS IS COUPLE MONTHS NEW. IT WORKED ONCE OR TWICE IDK HOW THOUGH. AND NOW I'VE TRIED IT ALL BUT STILL CANT FIGURE IT OUT. i went into the zone control and turn off the rear and i still have nothing. pleease help
Oct 08, 2007 | Kenwood KVT-617DVD Car DVD Player
No audio
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Sep 19, 2007 | Onkyo TX-DS494 Receiver
Motorola DCP-501 Receiver Logo
21 people viewed this question
Top Motorola Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
richie46
GASTON CHOUINARD
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
