Stylemaster no 4213575 rev d whirlpool won't spin
philbran
  • 242 Answers
SOURCE: washing machine does not spin
If the unit is making noise while set to spin but not spinning replace the motor coupling for the fix.
If the unit is silent when set to spin replace the lid switch for the fix.
Both are very common and not expensive plus easy to find online with the model number under the lid. Let me know if you have any other questions.
Phil
Posted on Apr 11, 2009
  • 13 Answers
SOURCE: Whirlpool washer stylemaster 4213532 won't spin,
check the connection of the plug if have power.check the motor should be 6ohms reading of motor windings
Posted on Mar 06, 2010
SOURCE: My Whirlpool stylemaster 907675 Washer wont spin..
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Posted on May 24, 2010
caroldon
  • 17130 Answers
SOURCE: After the first cycle the washer hangs up on the
Please check iff the motor speed is good enough. If slow check on the capacitor and replace the capacitor.
If this wont improve then the controller unit is a possible suspect.
Make a diagonistic check on these two sections and the possible answer migh help.
Posted on Aug 24, 2010
  • 183 Answers
SOURCE: Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Posted on Jan 03, 2012
Whirlpool washer Stylemaster #4216273 REV A allows water to go out of the machine but will not go into a spin.
the motor has an issue prob brushes need replaced or timing of the pump out is too long
check out the filters or get a tech...
Dec 10, 2014 | Whirlpool Washing Machines
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Jan 02, 2012 | Washing Machines
After the first cycle the washer hangs up on the first spin cycle. During this time it makes a hum but does not progress forward. You can move the control dial to the last spin cycle and it will...
Aug 24, 2010 | Roper RAS8445KQ Top Load Washer
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Whirlpool Washing Machines
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
