Question about Epson Stylus C64 InkJet Printer
USING OHP TRANSPARENCIES
WOULD LIKE ADVICE ON HOW TO SET PRINTER TO USE OHP TRANSPARENCIES FOR PRINTING
  • 749 Answers
You can't use ordinary transparencies if you use ink... find a special transparency that is sold by Espon, but that's rare to find now... only Laser printers can print color or black on ordinary transparency
Posted on Oct 31, 2007
How to disactivate or bypass the OHP sensor on the phaser for semi opaque paper (calc paper)?
Hi Rich,
Thank you for your lengthy and informative question that does help.
My first thoughts:
Did you try and tell the driver what particular type of paper you wanted to print on such as none Xerox recommended.
A thought just occurred if you were wanting to print transparencies then the printer would have to print strong colours at 100% because once you place the image on a OHP the image would look really washed out.
All the Xerox printers I've ever worked on don't have sensors that look at the opaqueness of the media, they do however have transparency sensors because once the edge of the paper has been detected a jam could occur, so lever type sensors are used to actually feel the media.
Good luck.
May 26, 2015 | Xerox Phaser 7400DN Laser Printer
I was wanting to know if you can copy on to transparencies on the DSc332 copier.
yes you can copy on transparence via stock by pass, set the bypass to special paper, transparency/OHP, size of transparency ex. A4
Aug 25, 2011 | Gestetner DSc332 Copier
My epson c2000 printer have a "service req e033"
Because the Epson AcuLaser Color 2000 was made for Latin America, there's not much information that I can give you concerning your Service Error Condition. All I can tell you is that the Service Request error # E033 is an Engine Related Service Call Error Message for OHP Detection Sensor Malfunction [abnormal condition]. Check to see if the windows on the OHP sensor are dirty and clean OHP sensor window and the OHP sensor reflective window. I'm sorry, but I can't even tell you where the OHP sensor is located, or anything else about it. If you cannot figure it out using your Owners Manual/Users Manual, you can always e-mail Epson Technical Support for possible help or advice, at epson.com
Mar 10, 2011 | Epson AcuLaser C2000 Printer
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
When printing in color, the color runs
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb), OHP transparencies, postcards*, letterheads,
colored paper, envelopes, label sheets, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray
Jul 13, 2010 | Samsung CLX-2160N All-In-One Printer
Can I print on transparencies with my canon mp150 ? If so, what settings/icc do I use?
Yes, but they need to be specially made ink jet transparencies such as this:
Amazon Inkjet Transparencies
Canon recommends their own CF-102 transparency sheets. Set paper thickness lever to the Left and the Media Type to Transparency.
See page 17 of the manual for a list of all Canon specialty papers. Here is a link to the manual:
MP150 Manual
Thanks for using Fixya.
Aug 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
May 24, 2009 | HP LaserJet 4300n Printer
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
Epson Stylus C64 InkJet Printer Logo
318 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
