Question about Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA Receiver Car Video Player
Dual xdvd110bt the wire coming from head unit thats suppose to be the parkin brake ground so where is the parking brake ground located on 93 nissan altima
2 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: need help bypassin parkin brake wire
you need to hook up the foot brake like it said but hook up a switch on the parking brake wire to ground do not hook it up to parking brake just a switch ground one side ant togle it while your foot is on the brake once the screen is on leave the switch in that position you will have to do this every time you turn the car off but you can see the screen while driving
Posted on Apr 08, 2009
Connected a Dual XPA2100 300 watt amp to the battery and connected ground to chassis of vehicle. Vehicle is 2004 Saturn Ion with battery located in trunk area. Amp does not power on, all connections are...
The remote wire DOES need to be connected to the head unit. You can see if thats the problem simply by touching the remote wire to the power wire. The unit should come on. The head unit should either have a remote lead, or a power antenna lead, and thats what you need to turn the amp on and off. BE SURE your ground is solid, and its usually best to take that to the battery as well to prevent unwanted engine noise. Hope this helps!
Sep 25, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Need help bypassin parkin brake wire
Mar 21, 2009 | Alpine CVA-1004 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 25, 2008 | Dual XDVD8181 Car Video Player
Aug 23, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Xdvd710
No - there aren't any codes to unlock the playback without the e-brake.
Aug 15, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 31, 2008 | Dual XDVD8181 Car Video Player
No picture
Jun 27, 2008 | Dual XDVD8181 Car Video Player
Cant get unit show dvd's
sounds like dual zone is activated, itll allow you to play dvd in back but not when youre driving. you may have to frig the unit to allow dvd display whilst driving, this usually involves a cable thats supposed to connect to your handbrake.
copy and paste link into your browser toget manual:
http://service.us.panasonic.com/operman/findmanual.aspx?model=CQVD7003U
Mar 22, 2008 | Panasonic CQ-VD7001U Car DVD Player
Car Audio & Video Logo
43 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
