Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
I cannot scan text to worddocument - Epson Stylus RX425 Multifunction All-In-One InkJet Printer
    President:
  • 1,865 Answers
You have to use OCR (optical character recognition) program to scan text to word documents. Some printers come with this software, but some do not, and you have to purchase the software separately
Posted on May 19, 2009
How to convert scanning documents to MS-words
You are going to want to find any OCR software that works for your printer. OCR is 'Optical Character Recognition'. It will take the scan and convert it into a text document, which is either already compatible for MS Word, or easily converted itself.
Feb 24, 2011 | Office Equipment & Supplies
Tip
FULL BATTERY REPLACEMENT PROCEDURE
1) DOINGWRONG
I didn'tknow this at first, so I replaced the original pair of 600mAh NiCd withseemingly more effective 2400mAh NiMH, but it was useless, although thebatteries were new. I thought it might help if I left the shaver charging for aday or two, but the green LED was so faint it was clear that something wasgoing wrong. By turning power on, the blades turned for less than one secondthen the LED blinked red showing no power reserve.
on Feb 16, 2012 | Norelco Advantage 6735 X Electric Shaver
I want to scan text from a page.help me
While you are scanning an Doc, you need to change the scan type from Image to Doc.
Jul 16, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
How to scan in text formate in ricoh2030
You need an OCR (Optical Character Recognition) program such as Textbridge or Omnipage ect. The program should use your scanner to scan and then read the page(s) and save as text.
Jun 11, 2009 | Ricoh Aficio IS420 Flatbed Scanner
I am unable to edit documents that I have scanned. I have tried to download the OCR driver but I am still having a problem. Please help
If you are scanning text as an image, the image cannot be editred, because the computer doesn't know the image is text.
You have to scan with OCR to edit text.
You can use PaperPort to add text to scanned images
May 08, 2009 | Office Equipment & Supplies
When scanning, the scanned page is not readable from a third of the page down to two thirds of the page.
It is important that the item you scan comes in close contact with the scanner glass. If the resulting scanned image is not clear, check to see that the item is in full contact with the scanner glass. The scanner uses optical character recognition (OCR) to convert text on a page to text that you can edit on your computer.
  • If you scan text but cannot edit it, make sure that you make the following selections during scanning:
  • Scanned text might not appear on your computer exactly as it appeared on the original, especially if the original contains faint or smudged text. For example, some characters might be incorrect or missing. As you edit the text, compare the scanned text against the original, and then make corrections as necessary.
  • To change text scanning options, click the Scan Document Settings button in the initial What are you scanning? screen.
  • The OCR software is installed by default when you install the HP Scanning software during scanner setup. If you use the Custom option when installing the software, you can choose not to install the OCR software. Try reinstalling the software using the default install options.
  • Email to jdiaz@coretec.us
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Nov 07, 2008 | HP Office Equipment & Supplies
Edit a scanned picture
Take it into photoshop cs3.Type the text over the scanned text that u want to erase.resize the typed text to match the scanned one.
2)make a layer copy of the background layer.Turn off the original background layer.then, create a layer mask for the copied layer.and paint black over the area u want to erase, with the layer mask active.
If u don't no photoshop OR in case, u couldn't figureout what i said,then mail me ur scanned image and the text file to damy.damy.bobo@gmail.com. i ll fix it and mail u back the edited copy.THANK YOU!!!
Jun 24, 2008 | Microsoft Computers & Internet
Scanning
Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
The OCR software that i Recommend is ABBY Fine Reader.
Thanks
Riz
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Conversion of worddocument to pdf
You can get the software this site.
www.download.com
Feb 23, 2008 | Adobe Acrobat 7.0 Professional
EpsonCX3900 NOT SCANNING TEXT AND SAVING AS TEXT IN Vista
There is absolutely nothing wrong with either your system or the scanner device, its just quite normal the scanned document are often saved in PDF or a image file formats, All you need is a text converter software (OCR) through which you can convert the scanned image or PDF file to text document and the best part is that you can even edit the text of the scanned document and make changes if you would like to as well. Here is the link for the text converter software download.
http://www.charactell.com/scanstore/InstSocr.exe
Click on the link to download and install the software that you require.
Alternatively you can also copy and paste the link in your web b browser address bar and hit the enter key to start downloading wizard.
Regards
Malik Khan
Jan 21, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
