Question about KitchenAid KUDE40FXSS Builtin Dishwasher
Dishwasher stops after 1st cycle
Dishwasher starts up just fine but after about 10 minutes or so it cancels itself and drains with out any reason to do so
jsrock516
  • 5911 Answers
SOURCE: kitchenaid dishwasher just quit mid cycle?
Check your thermal fuse. The fuse is located inside the control panel on or near the main control board. It will be a bullet shaped component mounted with a white plastic clip with two wires leading from it. The fuse should read a short if good. Now...keep in mind, if the fuse blew it is usually for a reason. Replacing it may or may not correct your problem. In some model dishwashers there was a thermal fuse kit that was required to be installed which involved cutting the wires and using a wire splice to connect the new fuse. It seems that there was a design flaw where the gauge wire used in manufacturing would cause the thermal fuse to blow prematurely due the wire overheating. I can't remember if this applies to KitchenAid, but I believe it does. You may inquire about this at your local parts store. I hope this helps you.
Posted on Aug 15, 2007
SOURCE: Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Posted on Aug 19, 2008
mohammed387
  • 1952 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
SOURCE: My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Posted on Mar 01, 2010
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
White residue on dishes when the dishwasher cycle has completed, not sure why, salt is fine. Is this limescale?
Hi
Make sure that the water is being heated up by your dishwasher. Also need to make sure that the wash motor is spraying water around at full force.
Best way to check this is to start a normal cycle about 10 minutes into the cycle open the dishwasher door during the cycle. 1st observe if the water was being sprayed around as you opened the door. 2nd feel the water and see if it has heated up.
Reset or cancel the cycle and wait for the water to empty. make sure it is draining properly and also check to see if filter is clean.
I'm inclined to think your machine is not heating the water.
Ash
Sep 09, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwasher stops after it starts
Your dishwasher is probably draining during the wash cycle. This is usually the result of a worn out diverter valve.
Nov 20, 2009 | Washing Machines
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
KitchenAid KUDE40FXSS Builtin Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
