Question about Toshiba 65H82 65" Rear Projection Television
Location of convergence chips for TV with missing tag
I have a convergence failure and the chips need to be replaced. The problem is that I bought the tv in a foreclosure sale and there is not only no manual with it, but also the tag on the back has been ripped off at some point so I don't know what serial # or year it was built. I've been told that if I know where to look for the chips I can figure out which ones I need. Can you help me with the location of these chips?
  • windsong74 May 22, 2009
    Thank you very much for the help. You are right with your asessment I believe. The unfortunate thing is that tvrepairkits.com does not have kits for Toshiba at this time. I did have success in changing the convergence circuits myself and was able to take care of 98% of the problem. The remaining problem is when switched on, the screen will flicker and display wavy lines that seem to go away as it warms up. The flickering stops within the first minute or so, but the wavy lines take up to 7-8 minutes to fully go away. I am left with a very slight red/ green line out of place on the lower right hand side of the screen. Is this casued by the resistor/pico fuse problem?
  • Toshiba Master
  • 3,459 Answers
Instead of winging the repair why don't you get a complete repair kit + instructions from www.TvRepairKits.com ?
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiLocation of convergence chips for TV with missing - 0667c5f.pngnvergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set thatLocation of convergence chips for TV with missing - 9e7eb5b.jpgfluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
9e7eb5b.jpgTV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 22, 2009
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 24, 2011 | Televison & Video
I bought this new 4 years and I'm deeling with green and red issues mostly on the left side
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Picture of a set that needs the fluid changed.
Dec 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
46" projection tv ..colours were
Projection TV sets have two very common problems oulined below.
  • Screen looks 3D
  • No Audio/Video - TV Makes Chirping Sound
Dec 16, 2010 | Philips 46PP9302 46" Rear Projection...
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
Cant figure out how to access convergence
Your TV most likely has failure in the convergence circuits. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Apr 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
60" phillips rp tv 3d/ glary and turns off when av is applied
Your TV most likely has one or more possible problems.
  • Screen looks 3D
Mar 28, 2009 | Philips 60P8341 60" Rear Projection...
Shadow images and scrolling banner curves upward and back down.
  • Screen looks 3D
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
The blu display on my sony 65" tv is arched, making the convergence adjustment in-effective.
its failure of Convergence Out IC chip and requires replacement.
TV has 2 IC chip in convergence circuit and I would recommend to replace both at same time.
Let me know exact model of Sony 65" TV to provide you more technical info.
Mar 14, 2009 | Sony KP-51WS510 51" Rear Projection...
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
Replacing convergence chips
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, etc.
Nov 15, 2007 | JVC AV-56WP30 56" Rear Projection...
Toshiba 65H82 65" Rear Projection Television Logo
363 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
