Question about Brookstone Aqua-Jet Foot Spa
Machine won't turn on.
The foot spa does not power up. Why not? Is the cord defective?
Need the cord to my singer machine: model 2250/ serial # ZHC928602149 Where can I get one?
Several online shops have Singer sewing machine parts. The power cord is integrated with the foot control. Sewing Parts online has the part on the product parts page: https://www.sewingpartsonline.com/singer-2250-sewing-machine-parts.aspx . The direct link is https://www.sewingpartsonline.com/foot-control-and-cord-singer-359102-001.aspx . Singer also has the foot control and cord: https://www.singeronline.com/2250.html . Note: make sure to order the power cord appropriate for your location. These sites have the foot control for 120V (for North American outlets).
I hope this helps.
Oct 25, 2017 | Singer Sewing Machines
Sewing machine was shocked it won't turn on when plugged
this is all i can find out at the moment.Check the electrical outlet for power and reset the house circuit breaker if the outlet is dead. Replace the outlet cord if it's worn or damaged. Unplug the sewing machine and check for loose wires. Replace the on/offswitch if it's defective.
Sewing Machine Won't turn on ' Symptom Diagnosis - Sears PartsDirect
https://www.searspartsdirect.com/sewing-machine-repair/symptom/SMAC2200003.html..
or go to this link might help you out.. Sewing machine won turn on Google Search
Oct 23, 2017 | Sewing Machines
The light on my singer Quantrum 9910 won't light up and it won't sew any embroidery stitches
This can have several causes. It appears, though, that you are not getting any power at all. That can be a defective power cord or power outlet, the bobbin winder spindle is pushed to the right, the presser foot is not lowered, the buttonhole lever is down but the buttonhole foot is not on. It also, of course, can be caused because your motor has failed, but that is the least likely.
Mar 18, 2017 | Singer Sewing Machines
Bernina 1006 foot peddle does nothing
Not sure. It could be something to do with the foot control, power cord, or the motor. Does the light come on? If so, it's probably not the power cord. If you have access to another foot control and power cord, that is an easy way to test. Otherwise, might be best to take it to a Bernina technician.
Bernina 1006 Parts
Bernina Foot Control Power Cord for 1000 800 Series
http://www.drdanessmh.com/berninaftc.html
Apr 03, 2016 | Bernina Sewing Machines
Intex Krystal clear saltwater system
I had nothing but trouble with that unit and it made its way to the dump minus the cord which I re-used as an extension cord,, I had a above ground 18 foot across and 4 foot deep and it never would make chlorine, which if your salt level is correct the machine does....
Mar 23, 2016 | Intex Automatic Salt Water System for ...
Helen troy foot spa
Review of hot spa by Helen of troy - YouTube
? 6:49
https://www.youtube.com/watch?v=GbyHTxzTabY
Mar 15, 2012 - Uploaded by Mrsdarkness2011
Review of hot spa by Helen of troy .... i have this same foot spa. pros: is it can heat cold water, cons: doesn't have adjustable heat temp, not ...
Helen Of Troy Hotspa Professional Ultimate Foot Bath
footbathreview.net/helen-of-troy-hotspa-professional-ultimate-foot-bath
An unbiased review of the Helen Of Troy Hotspa Pro foot bath. Helen Of Troy offers several professional foot spa products and this foot bath has one of the.
www.amazon.com > ... > Electric Massagers
Amazon.com, Inc.
Rating: 3.8 - ‎12 reviews
Amazon.com : Helen Of Troy Hotspa Professional Ultimate Foot Bath : Foot Bath ByHelen Of Troy : Beauty.
Helen of Troy Europe Owners Manuals »
www.hot-europe.com/support/owners-manuals/
Dedicated to delighting the consumer. We aim to make reliable & long lasting products. However, in the unlikely event that your appliance requires servicing ..
Jan 13, 2016 | Hotspa Helen of Troy Professional Foot...
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
Have a Pentair Easy Touch. Says spa water temp is 86 thermometer in spa says 96 have it programmed for 104 and indicator is on for heater but can't get it higher. Rheem heater is turned all the way up
could be the heater is defect, the thermostat is defect or the thermometer is defect. Try to rule out 2 of these and you know what is wrong. Or het heater just does not get any power?
Nov 01, 2014 | Pool & Spa
Why won't the breaker on the power cord of my intex krystal clear saltwater system reset?
Defective breaker or shorting pump. Disconnect the appliance from the cord. Does it reset? yes means your appliance is bad. No means that the breaker is bad. A cord with a breaker is not the way to safely operate the pump. You should use a ground fault protected outlet or a cord with a GFCI built in. Either way if the safety device continues to trip, you have a problem with appliance.
Aug 03, 2014 | Intex Krystal Clear Saltwater System Pool...
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
Brookstone Aqua-Jet Foot Spa Logo
74 people viewed this question
Top Brookstone Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Brookstone Pool and Spa Expert? Answer questions, earn points and help others
