Question about Hunter Dryers
Remote fan 86682-01 - Hunter Dryers
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Two fans with the same remote code.
There are dip-switches in both the remote and the fan. You need to change the switches on one of your fans.
Jul 14, 2009 | Universal Remote Control Hampton Bay...
I have a floor fan and the remote isn't working.
check IR receiver on the fan circuit board, resolder the lead.
Jun 19, 2009 | Holmes Products Holmes HT35R-U Tower Fan...
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Remote Chewed Up
i had similar problem with remote , went to home depot to buy a new fan and saw they had new remotes and receivers for the hunter fans , i bought the kit ( which had a remote and a receiver for a non remote ceiling fans) and was working again . salesman was very helpful .thanks.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Fan with light (no remote) with wall switch not a 3-way
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
Dec 04, 2008 | Hunter 52" Ceiling Fan With Light And...
Two ceiling fans, both remotes control the same fan
Most likely the dip switches on the remote receivers don't match (on the second fan, the one that doesn't work). While the remote dip swithes on both remotes match the working fan. You can simply reset the dip switches on the second fan receiver to match the one working remote, i.e. you don't need to have a second remote, one can work both fans as long as the codes (dip switches match). If you want you can make all the remotes the same, that way you have two remotes, or if you want them independent each remote and remote receiver must have unique codes (dip switch settings).
Nov 30, 2008 | Universal Remote Control Hampton Bay...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Dryers Logo
130 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
