Question about Air Tools & Compressors
How do i stop the air leaking
Campbell hausfeld air air compressor air wont stop leaking after motor shuts off on model #vt619500aj
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 174 Answers
SOURCE: Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Posted on Jun 22, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
SOURCE: electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Posted on Apr 07, 2010
Testimonial: "thank you, this has had me stumped for days now. simply flipping the pressure switch off then back on again solved the problem. "
  • 3 Answers
SOURCE: Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Posted on Oct 31, 2010
My Campbell hausfeld air compressor runs to 20 psi and then motor starts to bogg and then stops but motor still trying to run? Please help!
dont know size of unit ---if 220 check power in- under that will bog motor same with 110v --if using extension cords to long a feed from source and your voltage drops from resistance in wires ---motor may need service oil bearings --same with compressor motor oil change/needs oil added
Jul 12, 2016 | Campbell Hausfeld Air Tools & Compressors
Campbell hausfeld 60 gallon sight glass oil leak
Try here http://www.about-air-compressors.com/campbell-hausfeld-air-compressors.html
Jul 30, 2012 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld Air Compressor 1.8hp 135 max psi 20 gal wl611800aj the prob is there is a fluild leaking from the motor
You compressor is listed as being oil free. The only liquids that could possibly leak out of the motor (if still from factory condition) is black substance from overheated capacitor/s or grease from a failing bearing. Remove capacitor covers and check for failed cap. Motor bearings will become noisy before failure. Capacitors are available from motor repair shops and many times on ebay. Replace with same uf rating and same or higher voltage. Some caps are larger /smaller with same reading (notice size so cap cover will fit). Good luck
Jul 11, 2011 | Campbell Hausfeld 1NNF5 Air Compressor,...
My Campbell Hausfeld compressor model WL650101AJ will only pump to 80psi and will not shut off.
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Jan 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
Electric compressor motor problem
Apr 06, 2010 | Campbell Hausfeld 26 - Gallon Air...
Charge unly to 60 pnds,MOdel wl 6166 26 gls. I change the pressure switch look for air leaks seems to ok
The pressure switch only starts and stops the motor, if there are no leaks and it will not build pressure, then the pump has lost its capacity.
Feb 12, 2010 | Campbell Hausfeld Air Tools & Compressors
Air Tools & Compressors Logo
15 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
