Question about Canon PC-428 Color Copier
Paper tray feed
I need to replace the multi-stack paper tray and the copier tray on my home Canon PC 428 copier. I cannot find the above mentioned replacement parts. Any help in locating them would be greatly appreciated. loyd-mineark@missouri.edu
old marine
  • 2005 Answers
SOURCE: FRONT PAPER FEED
Go to this site. In the search window in the center of the screen, type "paper tray" and click on the Search button. Select the link "How do I load the paper". When the document comes up, select the link "Cassette" near the top. You will see illustrated step-by-step instructions. If you are missing the cassette tray, contact Canon.
Posted on Feb 05, 2009
  • 566 Answers
SOURCE: my canon printer/copier does not feed paper in
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Posted on Sep 06, 2009
SOURCE: canon pc 430 feeder problem
You may have to fabricate a new anchor for one end of the spring on the side opposite the control panel. There is a wimpy plastic tab that breaks off here, right next to a black Phillips-head screw. Remove this screw and bend a piece of light wire around it, leaving a small hooked end sticking out for the spring to fasten on to. Replace the screw and install the spring. When you install the spring, it must go over the top of the tiny white plastic wheel, in the U-shaped groove.
This is how I repaired my PC430 several years ago and it's still working fine.
Posted on Nov 08, 2009
canontech
  • 1219 Answers
SOURCE: in A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Posted on Jan 13, 2010
SOURCE: My old Canon NP1215 Copier: -First copy is
change drum unit still making lines
Posted on Mar 03, 2010
What is the reason Drawer 1 feeding two or more papers in photocopier canon 2320L
The separation pad is probably worn out. This pad creates friction against the bottom of the paper stack to stop multi-feeding.
Aug 28, 2016 | Canon Office Equipment & Supplies
I was given a Canon pc-428 with no manual. How do I load paper?
there is a tray that you have to open from the part that clicks
Jan 24, 2015 | Canon PC-428 Color Copier
My Canon 6512 photo copier machine does not take the paper beyond the pickup/Feeding assembly/ it stacks around the developing assembly (OPC Drum)
Dear
the paper first picked up from tray and feed up upto registration sensor and stops for a while, then image formation starts, paper flows to heating assy..
You have not mentioned any error code and jammed area detail. also check the life of the feeder assy. and pickup roller.
Before doing activities do clear all error in the machine list.
Thanks.
Jan 03, 2015 | Canon Office Equipment & Supplies
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
HI we have a Canon Pixma 780 printer. We changed where the printer takes the paper from when printing to the back of the machine. We want to change it back to taking the paper internally as when you print...
First thing to check is that the paper guide at the back is set. I've seen so many printers (of all makes) where the guide is not set at all.
Put a stack 20 to 30 sheets in the rear paper tray. Make sure that the stack is snug up against the right hand side of the feed tray (as you look at it from the front).
Then, make sure that paper guide - the little light grey plastic sticky-up bit at the left hand side of the feed tray - is moved up snug to the stack of paper. It should touch the paper but not squeeze it. Now try printing.
That guide is what makes the paper stay straight. If it does not touch the paper then the paper will go out of line.
This applies to all makes of printer and all types of printer.
Sep 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pc 25 not pulling paper completely through from tray or from manual feed tray.
hi,clean feedrolls & paper transportation.clear any misfeed sheet in paper supply section.send me result.
thank you.
May 28, 2009 | Office Equipment & Supplies
Paper won't feed. Message says paper tray empty but it isn't
Hi
Please press the button above HOME and it should change the tray in which you are printing from .
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Office Equipment & Supplies
Paper does not feed
Take it apart and clean the roller assembly.
Fan the paper stack before placing it in the tray.
Insert about 25 sheets at a time
Apr 15, 2009 | Dell Office Equipment & Supplies
Jamming while picking up from front tray
Have they tried to clean or replace the paper feed clutch? Also, do you have one or two paper trays? If you have two, did you try to feed the paper in the other paper tray? Also, try to flip the paper over, it may have moisture in it. Have you tried other types of paper? How about have you tried the manual by-pass tray? Will it feed that paper? Also, try that paper in another copier or printer, if it works, it has to be something with the copier it self. Just a note is the paper Glossy or a flat finish? Are you sure the parts were replaced? You may need to get a second oppion on the problem.
Aug 12, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon PC-428 Color Copier Logo
26 people viewed this question
old marine
old marine
