Question about Danby DWC612BLP Wine Cooler
Temperature Hi, I have a wine cooler Danby DWC612BLP, 75 bottles since 2005. Yesterday, I noticed that the temperature was at 24C(76F). The light and the display are working. Could it be the compressor or something else? Thanks.
  • 883 Answers
SOURCE: too warm
somehow the freon has leaked out, verified by compressor running long times without stopping.
Posted on Jun 08, 2007
Demy
  • 20 Answers
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
  • 1073 Answers
SOURCE: Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Posted on Apr 12, 2008
  • 6 Answers
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Posted on May 27, 2008
SOURCE: Keg freezing!!!!
I have had this product for 2 months and this just started happening to me also.
Posted on Jun 12, 2008
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
Repair door gasket seal
try there for parts enter model http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC612BLP/3055/0169000?pathTaken=&prst=0&shdMod=DWC612BLP
Apr 27, 2014 | Transtherm Furniture
Where can I get a relay for a wine cooler model jc 145b2eq? Uberhaus
its not the good number but try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC612BLP/3055/0169000?pathTaken=&prst=0&shdMod=DWC612BLP
Apr 24, 2014 | Furniture
Want to install a new thermostat. where does it go in a DWC612BLP cooler
Hey, man go there you have the plan for your equipment
Feb 20, 2014 | Danby DWC612BLP Wine Cooler
Woke up one morning to frozen bottles of wine. The Digital Thermostat still said it was at 8 degrees celcius, but was much colder than that.
Most of these types of wine coolers are not brand names and parts are hard to get. If you paid under $200 for it, buy a new one.
Otherwise you will need to have it repaired by a service station or someone who can get the thermostat and or control board, which is very minimal with these coolers.
You can search for parts if you want to DIY. Search for parts using description and make and model.
Good luck.
Nov 19, 2011 | Danby DWC612BLP Wine Cooler
We just received our Danby 35 bottle wine fridge with digital temperature display, and cannot turn off the light.
I found the users manual for your Danby! You have erroneously called it a 35 bottle unit, when in fact it is a 50 bottle unit. Click HERE for you manual. In the manual, it says you can use the light manually or automatically. There appears to be a switch on the bottom of the unit. I suggest the manufacturers manual for it holds a great deal of information that can be of assistance in the future, as this is a discontinued model
Good Luck, and I hope this is the answer you are seeking. Please rate and comment, Thank You Joe
Sep 07, 2011 | Danby Silhouette DWC512BL Wine Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC612BLP Wine Cooler Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
