Question about GEORGIAPACIFIC Georgia Pacific Dispensers SofPull Dispenser, Translucent Black
What does the display light on the left side of the led display panel mean
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
I have LED 32" problem with display
Back-light inverter board problem. Contact any service technician.
Gopakumar Gopalan Google
Apr 11, 2014 | Televison & Video
I have fluke 789, now there is no display only at the left side have 3 led light on ,
you can try replacing lcd, if that does not fix problem then send it in for service
Feb 12, 2014 | Science & Laboratory
White screen at bootup
Dell Support > Inspiron1564 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1564/en/sm/index.htm
http://www.insidemylaptop.com/replace-broken-screen-dell-inspiron-1564-laptop/
Let's start with two small primers first;
A) An LCD screen cannot produce light. It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Dell Inspiron 1564 Notebook PC can come with either a CCFL backlight, or LED backlighting.
http://www.laptopscreen.com/English/model/Dell/INSPIRON~1564/
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[ Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
Basic example. Look at the last 9 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and Backlight.
For LED backlighting a screen Inverter may not be used.
B) For a Dell, video cable is Display Cable.
LCD screen = Display Panel
Switch Cover = Power Button Panel
(Cover that is a strip of plastic essentially, that is above the Keyboard, and below the LCD screen. Has Power On button)
Display Cable:
The display cable attaches to the motherboard, in an area under the Power Button Panel. (Above the F2 and F3 key, approximately)
It then routes under the left Hinge, and up into the Display Panel Assembly.
From there it attaches to the screen Inverter, if used, and to the back of the LCD screen.
A example of the cable,
http://www.ebay.com/itm/DELL-INSPIRON-1545-LCD-FLEX-CABLE-LED-R267J-NEW-/370491513861?pt=US_Laptop_Screens_LCD_Panels&hash=item564303dc05
The cable may become pinched in the left Hinge. This can cause pulling on the cable, and/or damage.
Pulling may cause loose connections of the cable. Loose at the motherboard side, or LCD screen side.
Doesn't take much of a loose connection to get issues like what you are seeing.
In fact it may be so minute (My-noot) that it won't be visually seen.
The ONLY way to be assured the connections are tight, is to PHYSICALLY check them. Try to plug them in tighter.
This means checking the display cable on the motherboard side, and LCD screen side.
http://support.dell.com/support/edocs/systems/ins1564/en/sm/powerpan.htm#wp1061007
The Power Button Panel contains the Power On button/switch.
It can be removed, and laid over so that the motherboard connection can be checked, with the Power On switch still attached. This way after physically checking the connection, the laptop can be turned on, and display checked.
[Lay the Display Panel Assembly back as far as you can. Suggest covering screen with soft cloth, or suitable device to protect screen.
Screen has to be handled as if it is good, until diagnoses shows differently.
If the Power Button Panel cannot be laid back far enough, to get out of your way, unplug the Power Button cable. Plug back in to check display.
ALL power removed BEFORE disassembly.
Replace Battery, and AC adapter (Charger) when going to test display, after checking connection ]
For the LCD screen (Display Panel) side of display cable connection,
remove ALL power, then,
,disassemble down to Step 7. This way you can lean the screen out, and check the connection.
Display Panel connection physically checked reinstall power, turn on, check display.
IF there is obvious visual signs of damage to the sheath of the Display Cable, there may also be damage to the tiny wires inside.
(Stretched/Broken)
A continuity check with a multimeter is warranted.
If the Display Cable's sheath does Not show obvious signs of damage, it is still best to perform a continuity check, so you can Positively rule out the Display Cable as the problem.
Suggest go to a local 'Mom and Pop' computer store, and for a coupla' bucks have them check it.
Or replace it.
Display cable checks out 5by? (OK)
Go on.
Screen Inverter:
The next item to check is the screen Inverter, IF a screen Inverter is used.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
One example of an Inspiron screen Inverter,
http://www.ebay.com/itm/New-Genuine-Dell-Inspiron-1545-Series-Lcd-Inverter-Board-15-6-H251M-0H251M-/300756244730?pt=US_Laptop_Screens_LCD_Panels&hash=item46067818fa
Yes. It's an Inspiron 1545 screen Inverter. Couldn't find a listing for an Inspiron 1564 screen Inverter. Means to me that most of the 1564's use LED backlighting, or everyone is switching to an LCD screen that uses LED backlighting.
Display Panel:
If the screen Inverter checks out, the problem is the Display Panel.
(LCD screen)
IF there is No screen Inverter used, the problem is the Display Panel.
I'm willing to bet you have a loose Display Cable connection, or damage to the Display Cable.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ For the areas you are going in no ESD wrist strap is needed.
It IS however, always a good practice to wear one, and have it's alligator clip attached to a good ground source.
Electro Static Discharge.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer. (Laptop or Desktop)
Doubtful that you will see it, or feel it. Poof! Your computer is fried.
An ESD wrist strap relieves your body of Static. You CANNOT just touch a metal frame of the laptop to relieve your body of Static, like you can a desktop computer.
Average cost is around $3 to $6. One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I do not feel an anti-static mat is warranted.
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or use a large metal knickknack (Unpainted ]
Oct 14, 2012 | Computers & Internet
Front panel configuration
Motherboard installed in computer case;
Processor to the Top, 3 Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
Down in the Bottom/Right corner, is JFP1, and JFP2.
The Front Panel header is JFP1. (Junction Front Panel 1)
The header with two rows of pins, and is positioned Horizontal. It is parallel to the bottom of the motherboard.
(The other Front Panel header is JFP2. It is positioned Vertical, and is above JFP1. You may be using it also. Read on)
There are two rows of pins for JFP1.
5 across the Top, 4 across the Bottom.
The pins on the Top row are numbered ODD.
The pins on the Bottom row are numbered EVEN.
Top row, starting from the Right side, going towards the Left;
Pins 1, 3, 5, 7, and 9.
Bottom row, starting from the Right side, going towards the Left;
Pins 2, 4, 6, and 8. There is NO pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the Harddrive activity LED light is dim, when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is/was for the factory.
D) Pins 2 and 4 are for the Power On LED light. A Power On LED light that has 2 wires.
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Looking at JFP2. (Junction Front Panel 2)
Vertical with two columns of pins.
3 on the Right side, 4 on the Left side.
The Right side is numbered EVEN.
The Left side is numbered ODD.
Starting at the Bottom on the Right side, going Up;
Pins 1, 3, and 5.
Starting at the Bottom on the Left side, going Up:
A) Pins 1, 3, and 5, are for a Power On LED light, that has 3 wires.
Pin 1 is for the Positive wire. (Dual color LED )
B) Pins 2, 4, 6, and 8 are for a Speaker. The speaker for BIOS Beep Codes.
Pin 8 is for the Negative ( - ) wire.
Regards,
joecoolvette
Jun 24, 2012 | MSI MS-6580 Motherboard
My LED Television has a yellow line going down the left side of it, is it fixable?
I would say probably not. You have a whole row of blue LEDs that aren't lighting up; the display controller circuitry is probably toast. As far as I know, the only way to replace that is by replacing the entire screen.
Dec 31, 2010 | Televison & Video
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
is the Front Panel header.
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
How to interogate a samsung RB215LABP fridge through the display
I am an authorized Samsung service company, and, according to my diagnostic code quick guide this LED reading should be ignored. It is labelled as an Uart COMMUNICATION ERROR.
I hope this will help you, Ward Appliance Repair.
Dec 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Whirlpool Duet Dryer GEW9250P (electric)
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Sep 13, 2007 | Whirlpool GEW9250P Electric Dryer
GEORGIAPACIFIC Georgia Pacific Dispensers SofPull Dispenser, Translucent Black Logo
213 people viewed this question
Top GEORGIAPACIFIC Home Experts
Donni Steen
Tom Chichester
Are you a GEORGIAPACIFIC Home Expert? Answer questions, earn points and help others
