Question about Dishwashers
Simpson dishwasher eziset 52b850
It does not drain water. I checked all hoses and connections. All clean. I even use finish cleaner one a month and clean filters once a week.
3 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: dishwasher will not drain water
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Posted on Jan 21, 2010
  • 20 Answers
SOURCE: Simpson eziset 52b850 how to
Plug in machine and turn power switch on. Then press the front left hand power switch on and the select program and finally press the large right hand start switch.If you wish to change or reset a program hold the previouly selected program button in for 10 secs and the reselect your program choice and hit sart.
Posted on Dec 23, 2010
Recently had a leak in our water pipe between mains and house.We had the pipe replaced.Then the washing machine wouldn't fill so we replaced solenoid valve-it works now. The dishwasher won't fill now
when the pipe was repaired , there is every possibility that dirt got into the pipe and will affect all solenoid operations and taps
remove all hoses and flush the pipe out well
Oct 21, 2016 | Simpson Washing Machines
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
Simpson dishwasher eziset 52B850
You can try google search and find solution.
Sep 03, 2013 | Dryers
Water won't go down drain.
It appears that you have a drain pipe problem. Check that the hose is not restricted ( kinks etc) Get a good drain cleaner that you can use in you machine and clear the gunk out of the hose. Contact simpson dealer for a compatible product to do the job as some drain cleaners react with the steel and hoses.
May 06, 2013 | Dishwashers
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
Simpson eziset 52b850 how to power on the dishwasher??? And how to use it.
Nov 06, 2010 | Dishwashers
Hi, my Simpson eziset 605 doesn't hold any water. It fills and drains straight out then flashes and beeps HC on the display. Any ideas why?
check that the drain hose is not lower than the water level. If it is, the water will simply drain away by gravity.....Nomess
Apr 19, 2010 | Washing Machines
Simpson eziset 450
It sounds like the drum is so away from level that water is not flowing to the drain line, hence the pump running out of water. I would make sure the machine is level and the drum is resting level if it's the type that pivots around inside the machine. Failing that I would open up the machine and check the hoses to make sure they're not blocked. I would also check the drain hose to make sure it's not placed too high or in a way that will obstruct water flow.
Oct 19, 2009 | Washing Machines
Bad smell in Simpson Eziset 550
pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
Sep 06, 2009 | Washing Machines
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
