Question about Sharp R-1470 Microwave Oven
Online manuals WHERE IS THE FUSE
Panasonic Microwave Oven unexplainedly without power. Model No. NNS954WF. Serial # 6A34160395.
If you remove the microwave case, follow the power cord inside the microwave to the fuse. Panasonics will usually have a 15 or 20 amp ceramic fuse available online or at a local appliance repair shop. Of course remove power from the MW and don't touch any wiring or terminals except the fuse wiring.
Nov 14, 2017 | Microwave Ovens
Microwave FGMV174KFA, No power, outlet works
If there is no power at all you may have blown the inline fuse. I have included a link to a parts source and to online manuals. Unless you are very experienced with high voltage electronics I would not attempt to repair a microwave yourself. There are mistakes that can make your microwave unsafe as well as very large capacitors that will still be charged even when unplugged. Please consider this before attempting this.
Parts
Parts Model FGMV174KFA Sears PartsDirect
Manuals
Manual Frigidaire Microwave FGMV174KFA
I suspect #17 on this page
Feb 18, 2015 | Microwave Ovens
Free downloadable manuals
Panasonic offers the manuals online via their FTP site (Google your model number plus the word manual), or via their web page (link below):
Panasonic Product Support
There are also numerous online sites that library manuals like this one:
Panasonic Microwave Oven manuals
Aug 19, 2014 | Panasonic Pansonic microwave
Homemaker EM930ASC Microwave oven manual
I found a similar model manual online that may help.
Generally the Homemaker brand did not have online manuals online, and users sometimes have posted scanned copies.
https://www.kmart.com.au/wcsstore/Kmart/pdfs/41928523%20-%2025L%20Microwave%20Convection%20Oven%20(Stainless%20Steel).pdf
Feb 19, 2013 | Microwave Ovens
Can I replace an internal thermal fuse in my jmc7000 jenn-air microwave?
It doesn't have a thermal fuse, but it has a 20A ceramic fuse and on or around the magnetron it has a thermostat.
The 20A fuse (if blown) can be had in local appliance parts store, and places like Lowe's Home Depot, and Wal-Mart.
For the fuse and/or thermostat, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If the fuse is blown and it blows again, it may be a loose fuse holder, shorted high voltage capacitor, or door switch trouble.
If the thermostat failed, it's due to a magnetron overheating due to the internal cooling fan's not working, or just the magnetron itself going bad.
As a bonus, you can find your owner's manual online here free.
If you need further free help, let us know.
Oct 06, 2011 | Jenn-Air JMC7000 Microwave Oven
I have a JVM1440 that has no lights or power at all. Unplugged and replugged unit but still no power. Could ift be the smart board?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.ajmadison.com/cgi-bin/ajmadison/JVM1440.html
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.ajmadison.com/ajmadison/itemdocs/PDF_GE_JVM1440_user_manual.pdf
And here is a direct link to the Online Parts List and Service diagrams for that model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216893
To view the Support Page, user's manual, or the service diagrams just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents like the owner's manual.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
I will assume you have checked the house's main circuit panel for any tripped brealers and tested the electrical wall outlet for a good power supply.
Hopefully the problem is just a blown main fuse inside the microwave. In order to access and check this you will have to disconnect the power cord and then remove the oven from the wall. Then remove the case in order to access the electrical parts inside.
Here is a diagram of the fuse location once you have the unit disassembled:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=21657924&pkw_=basket&model_id=216893&NewWindow=1
The fuse is item number 47 on the diagram and parts list.
Here is a picture of the main fuse on that model:
http://www.appliancepartspros.com/part_details.aspx?part_id=2631556
Just replace the fuse with an exact match and reassemble. If you tested the old fuse and it was still good, then you may be dealing with a more complicated and expensive fix possibly involving the control panel circuit board. At that point you may want to consider seeking additional assistance or just getting a new oven.
Thank you very much and good luck.
May 11, 2011 | GE JVM1440 Microwave Oven
Microwave stopped working, and its not very old. I wanted to know if it was the fues? How to replace it. 2008 i think LMV1680st
http://www.lg.com/us/appliances/microwave-ovens/LG-over-the-range-microwave-LMV1680ST.jsp
You can download the owner's manual from the support site if you want, just look under the SUPPORT tab.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520022
To view the Support Page or the service diagrams just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700124&pkw_=basket&model_id=5520022&NewWindow=1
The fuse is item number 5001 on the diagram and parts list.
http://www.appliancepartspros.com/part_details.aspx?part_id=4440371
Joe.
May 11, 2011 | Microwave Ovens
I need a copy of the operating manual
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 08, 2011 | Microwave Ovens
I want to download the manual, I've lost mine.
The following sites have an extensive catalogue of microwave manuals:
Retrevo
Manuals Online
User Manuals Online
Mar 05, 2011 | Microwave Ovens
Panasonic NE1856 microwave. Located in small food shop. F3 fuse blows after 1/2 day of use. Fuse does not blow straight away. Have checked all the door switches.
It may be a failing high voltage transformer, or some models have a voltage selector on the back, and if it's not set to match the measured line voltage level at the outlet, that can cause fuse blows.
The service manual for this UK model is available for purchase / download online. You can check these Google search results.
(NOTE: Those links are not mine and I do not have this manual for sale. If I had it, I would offer it to you at no charge)
If you decide to buy the service manual and will send me at least the schematic page, I can probably tell you what's wrong or what I most strongly suspect after seeing the overall circuit.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 22, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
