Question about ProForm XP 210 Upright Exercise Bike
Can a replacement console be ordered for the proform xp210u upright exercise bike, if so do you know the price?
I have a Proform SR 30 recumbent bike and I need to replace the batteries that show the various modes. I can't find the battery compartment.
https://support.proform.com/parts-manuals/#bikes
Go to the above page and enter your bike information. You should be able to download an owner's manual AND....there is a 1-800 number to call for support.
Semper Fi,
Z
Jan 29, 2018 | Proform Exercise & Fitness
Exercise bike instruction manual
WARNING Do not attempt to open the back cover of the Monitor console. This is not a battery storage area; this Computer is powered by an AC Adapter. This bike is to be used only indoors and in a dry location. Do not plug the AC Adapter into the wall until the electronics monitor is completely assembled.
Jul 16, 2014 | Fitness Quest Edge 482U Upright Exercise...
ProForm 2.0ES Upright Exercise Bike - it won't turn on. Tried new batteries and a/c adapter. Won't do anything. Only worked for 1 month.
Wondering if it is new and therefore, still covered under warranty.
I am guessing something is creating a short circuit in the console which is shutting off. Have you seen page 11 of manual about protection of wires from pinching? Might be a good idea to open the console mounting and see if the wires and connectors are sitting ok.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX519120%20-%20PROFORM%202.0%20ES%20BIKE%5CPFEX51912.0-333356.pdf
May 01, 2014 | Exercise & Fitness
Chain keeps comming off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
No display proform 280ZLX bike low volume buz low freq from speaker on cct board will probably end up flattening 4 X AA batteries
Your console is faulty. There are no parts available for the console. ....you will need to buy the whole console.
Dec 01, 2013 | Exercise & Fitness
Preform 310 cx bike. I can't find where to plug in the adapter cord on the bike.
Usually with this brand it will plug into the back of the console. You may have to take off a cover where the batteries are to find the fitting.
Oct 05, 2013 | Proform 310 CX - Exercise Bikes
The console will not turn off with new batteries
Leave the machine for a few hours. You may not be giving it enough time. Also you may inadvertently changed the settings. Check that.
Sep 15, 2013 | ProForm XP 210 Upright Exercise Bike
What are the different types of exercise bikes?
There are three types of exercise bikes: upright bikes, dual-action bikes, and recumbent bikes. Upright bikes are standard exercise bikes that allow you to only use your legs (regular bicycling movement). Dual-action bikes allow you to workout your upper body as well by providing moveable handlebars. Recumbent bikes feature a bucket seat and the ability to recline while pedaling.
Aug 12, 2012 | Exercise & Fitness
The screen doesn't display a clear and legible display even when I'm peddeling
This sounds like a console issue. Your options are kind of thin on this one. I would suggest doing some research in order to find an option to have the electronics repaired in the console.
Feb 17, 2011 | Stairmaster 3400CE Upright Exercise Bike
Proform gr 80 recumbent exercise bike cant get the display to turn off when I get off bike. battery powered?
The GR80 uses for type D batteries. The battery compartment is on the bottom of the console, look for the D-shaped battery door, press the tab located towards the front side of the console and open the door. Careful, the batteries may fall down if you open the door - type Ds are heavy enough to be felt when they fall on your feet.
Jan 16, 2011 | Proform GT 85 x Upright Bike at GNC
ProForm XP 210 Upright Exercise Bike Logo
65 people viewed this question
Top ProForm XP Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a ProForm XP Exercise and Fitnes Expert? Answer questions, earn points and help others
