Question about Frigidaire ATF6000ES Front Load Washer
Front Load Frigidare washer bouncing on spin, very bad!!!
I have a brand New Frigidare Affinity front load washer model number ATF6700FS1 and I have tried 4 loads of clothes in it so far and when it goes to the high speed spin cycle it bouncing around so hard that it walks away from the wall and turns side ways. I have it in a bare concrete floor and all the legs are adjusted level. I have tried small load and large load of clothes in it and it works great until it goes to the fast spin cycle. I dont know what to do. It will tear its self up if I keep trying it.
I tried it empty and it runs smooth but with any clothes in it, it will not stay still. I vibrates so hard that it will scare you to death.
Please let me know what to do next. These are brand new and I just hooked them up.
Hi, not sure if you have resolved this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Posted on Jun 13, 2009
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidare (ATF6700FS1) reads error 23 it will not spin
Failure of the drain pump relay or associated circuit. IF the board is examined for any loose joints to the drain pump and confirmed then the solution is a replacement of the control board.
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer bounces when spin starts and seems nosie
If it is brand new are the transit bolts removed? try spin with nothing in it and see if it turns smoothly, if not there is something broken inside, id spins smoothly it will be a fault in the dampers.
Apr 18, 2010 | Frigidaire ATF6000ES Front Load Washer
My brand new Frigidaire Affinity is bouncing all
Need to be level in a concret floor, and not to close to a driyer.
Jun 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Hi, not sure if you have solve this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
Nov 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
397 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
